Using Directv HDDVR versus SDDVR
dontexas
Want to use our HDDVR in TT instead of our SDDVR previously used.
Dish is 18 by 20 model AU2F3. HD receiver is HR24-100. Am I good to go ???
Don & Donna Myers
2012 Nomad Joey 260
2009 Chevrolet Silverado 1500
22 REPLIES 22
Chuck_thehammer
slimline.. 5.(3 blobs on the hose). are you also using a "B" converter..
I have the same receiver... had to get a 60 dollar dish (antenna)... with the "B" converter, 15 dollars.
NO beeps...
I use a homemade LOW profile PVC pipe mount..
DIRECTV SlimLine 5 LNB Ka/Ku Slim Line LNB for Satellite Dish (SL5)
I get all the HD channels. and HD local channels.
Bill_Satellite
Are you using a SWM SL3 with a power inserter or a standard SL3. If the former, did you remember to bring the PI?
Can't we all just get along?
docj
dontexas wrote:
Op here, been a while since I did this setup and I have forgotten stuff (old age related ?).
Ivylog said slimline, ok which selection ?
03:Slimline-3 doesn't seem to be working..... Help ?
If you're using a SWM setup the correct selection would be SWM3, I believe.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
dontexas
Bill.Satellite Used this setup at rv all last summer. Can't remember satellite type used in setup.......
Don & Donna Myers
2012 Nomad Joey 260
dontexas
Has sl3 lnb (99/101/103)
Don & Donna Myers
2012 Nomad Joey 260
Bill_Satellite
Did you replace your old antenna? If not, you still can't get HD with a triple LNB antenna (oval dish or not). You must have the new SL3 LNB and I would suggest that you buy the SWM SL3 so you can use a DVR but require only 1 coax.
dontexas
Don & Donna Myers
2012 Nomad Joey 260
dontexas
All is well in HD world. Thanks Ivylog....
Don & Donna Myers
2012 Nomad Joey 260
Ivylog
Slimline.
Upgraded with a 08 HR Navigator 45โ€™...
sdetweil
chiefward wrote:
Do you folks with the Directv HDDVR 24-100 get a beeping sound when using the signal meter function? A DTV technician changed out my old dvr and I do not get any sound with the signal meter function.
no. the 24 doesn't beep.. they added it back on the 34 and 44 (Genie)
2012 Ford F350 DRW, 6.7 diesel.
2013 Keystone Alpine 3720FB
dontexas
Ivylog Replaced the LNB as per your suggestions. First timer out and have 1 question. In setup what dish shape do I select ? Thanks
Don & Donna Myers
2012 Nomad Joey 260
Ivylog
Bill.Satellite wrote:
There is NO HD available with that antenna. It will only receive 101, 110 and 119 and you need 101 plus 99 and 103. 110 and 119 are no longer of much use.
OP, if you replace the current lnb (for 101, 110 and 119) with a SL3 lnb (99/101/103) it will work for HD. Because of it's smaller size (easy to store) in the northern states and Canada the signal may be too week to get HD but it will still get 101 (non HD).
chiefward
2011 Fun Finder by Cruiser RV, model X210WBS
2017 Ram, 1500, Tradesman,
10,000 Equal-I-zer hitch
Bobbo
BILL.SATELLITE IS BACK!
Bobbo and Lin
