โFeb-28-2017 10:31 AM
โMar-17-2017 09:45 AM
โFeb-28-2017 08:44 PM
โFeb-28-2017 08:40 PM
โFeb-28-2017 07:06 PM
rk911 wrote:DwnSth wrote:I just downloaded and tried the 'Dog Monitor' app...and it seems to work. have to play with it more but it seems to do that job. how do you mount your phone/tablet in such a way to monitor the dog without the dog knocking it over?
If you can swing a spare phone, no need for a hotspot and plenty of apps to use. I currently use 'Dog Monitor' Which allows video and sound...
โFeb-28-2017 05:10 PM
โFeb-28-2017 02:36 PM
โFeb-28-2017 02:32 PM
โFeb-28-2017 02:12 PM
hedge wrote:GordonThree wrote:hedge wrote:
I would be careful with anything that is 'cloud based' it will likely use the bandwith constantly.
If you used more of a traditional method and use the built in web server of the camera with port forwarding it would only be using data while you are connected to it. just not sure if port forwarding is possible with those hotspots like on a traditional soho router.
None of the big 4 give you a public IP, at least, not on a consumer grade plan.
Not sure I know what a public IP is, do you mean static IP? dynamic dns services exists to keep it up to date so you can find your server.
โFeb-28-2017 01:18 PM
โFeb-28-2017 01:15 PM
โFeb-28-2017 01:05 PM
DwnSth wrote:
If you can swing a spare phone, no need for a hotspot and plenty of apps to use. I currently use 'Dog Monitor' Which allows video and sound. Also use Valarm to track temp with a remote sensor but it's a bit more involved to set-up. What I do like about Valarm is the ability to text/email when temp is out of range or sound (barking) is recorded. Between the two apps, I'm pretty comfortable with the dogs in camper and know I can peek at them anytime.
Would work with any data plan and I've never experienced much data use. Video is only using data when active.
โFeb-28-2017 01:03 PM
โFeb-28-2017 12:55 PM
