What's the deal with my new DVD player
Bobbo
I replaced my RV's failing DVD player with a Panasonic SC-XH150. I chose it because my old one was a 5.1 Surround Sound and the Panasonic is too, so the speakers were direct connect.
The Panasonic will not play ANY DVD that I own. No matter which DVD I put in, it says "incompatible format." What is going on?
Can someone recommend a DVD player compatible with 5.1 Surround Sound that WILL play? A Blu-Ray would be nice, but is not required.
Thank you
Bobbo and Lin
18 REPLIES 18
1492
Moderator
Moderator
Bobbo wrote:
No, it is NTSC. The menus all display on the TV just fine so that shouldn't be a problem.
I think you're referring to Panasonic's menu display and not the DVD's disc menu? You shouldn't be able to see the discs menu at all if there is a compatibility issue. Just an error message?
DVD players are actually very precise devices. It surprises me to no end that they survive near earthquake conditions in most rvs. And continue to work with few issues.
As an end user, I would have first played a music CD to confirm getting audio, and at least the disc tracking system is apparently working. But doesn't really address the DVD laser pickup. However, clean the laser pickup and test another DVD.
If still not working, look for available updated firmware. I've had issues where outdated firmware caused both BluRay and DVD players not to play discs. Just recently, we had a commercial high end BluRay player connected to a $150k Barco DLP projector not play certain discs due to a new commercial copy protection scheme introd 1-2 years ago. Flashing updated firmware solved the issue. This compatibility issue didn't effect all manufacturers. So the discs would play on some players, mostly consumer models, while not playing on others.
All other issues need to be addressed by a technician. DVDs are read from the inner disc outward. If the tracking system is out of alignment, issues with motor disc speed, or laser pickup, maybe even out of focus, the system cannot read the disc identifier or DVD structure files. And you'll end up getting playback error message.
But all a moot point at this stage as Panasonic is taking care of it.
Dyngbld
If you are parked near me I would be happy to look at it, but I would need the unit to do much else. Try resetting all the settings to default. pg 18 of the manual.
http://www.geocaching.com/profile/?guid=e7bd775c-4d1e-46d4-850d-e014153937be
Bobbo
This is the link. Last May when I bought it, it was available new. The one I got was new, never opened.
Panasonic DVD player
Bobbo and Lin
Bucky_Badger
do you have a link for the dvd player on Amazon
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Bobbo
Bobbo and Lin
Dyngbld
Is it PAL. US media format is NTSC. If you have NTSC dvds the PAL machine will not play them. Many newer units are multisystem and will play anything, but it is something to look at.
Edit: OK I looked at the the manual, it is a region 1 NTSC machine. You should be able to play any DVD you have. My guess is it is broken. Wouldn't be the first time an item gets broken during shipment.
Pg 18 gives instructions on resetting default settings. Try that if no luck take it to a pro. I would need the unit to trouble shoot anymore.
Bobbo
I'll try to hit all the ideas. There is nothing in the setup that affects this. I tried everything.
I am putting in the disc right side up, but wondered if the laser is on the top so I turned the disc upside down and tried it again.
It has nothing to do with the audio. The audio self test works fine and all of the speakers play at the correct time. It just won't read a disc.
I am using store bought discs that I have been playing in at least 2 other DVD players. Not Blu-Ray, not HD. Standard old DVD's.
I thought of the non-US region issue, but I bought it from AMAZON.COM, so I didn't think I needed to worry about a black market machine. It was ordered and fulfilled by Amazon.com.
The only thing I could think of was a problem from the factory. I dropped it off at a Panasonic approved repair shop today. We will see what they say.
Bobbo and Lin
wa8yxm
One possible issue (or two or three) is concealed damage during shipping.
True story: Where I worked we had a printer that kept messing up.. Well finally they set one up and tested it in MYC.. Put it in a box. The Tech sealed the box and shipped it (Signed the seal) hopped on a plane to Detroit, and received the shipment, Verified the seal and inspected the printer.. Some switches inside had changed state.. (By the way my boss accused me of changing them.. Plese.. Someone tell me how I managed to do this without breaking the seal on the box I did not even know existed?) (Or you can just spell BOSS backward.. Doubbel S...)
IT may be that the head got jammed up, or a cable came loose, in shipment and when that happens.. IT WON'T WORK
I have hardware that is like that.
dan-nickie
What type of DVDs are you trying.
Store bought?
HOme recorded?
Blue ray?
DVD HD?
Standard DVD?
And dumb question of the day - you are inserting the disc face up right?
The documentation does say it is for region 1 (US)
Dan and Nickie
2014 Forest River Berkshire 390RB
1492
Moderator
Moderator
Assuming its an audio issue, not picture, I'd suggest you go into the DVD player setup menu, and make sure that the "disc audio" is set for "Dolby Digital"? Not PCM? In addition, if given a choice for Dolby Digital PCM or Stream, it depends on what is decoding the Dolby Digital 5.1 data? If it's an all in one DVD unit, than most likely its Dolby Digital PCM. If using an external 5.1 decoder, than select Dolby Digital Stream, which just passes raw data. In any case, select one or the other until you are getting 5.1 sound. You can't really hurt anything.
If your unit won't playback at all, and getting the incompatible error message with all DVDs, than you can see if there is updated firmware available for download? Burn it to CD or DVD and playback to update. Or it could be an issue with the DVD pickup laser out of alignment or defective which obviously needs servicing.
SCVJeff
But there are plenty of DVD's open coded. Find a cheap DVD, something not produced by a major studio: kids cartoon, family DVD, RV sales DVD, etc., and see what that does.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
1775
This very much sounds like you were sold a DVD player that has been coded for a different DVD region than the one you are in. A DVD player made to sell in Japan or Europe will not play DVDs region coded for the USA. This has nothing to do with where the player was manufactured but where the manufacturer intended this particular player to be sold. It is not uncommon for electronics to be sold as "black market" in the US particularly over the internet.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
trb46
Is there maybe something in the setup menu that needs to be changed?
2011 Four Winds 23A
Only 48 more states to visit!
BB_TX
I replaced mine with a Panasonic blu- ray 5.1 home theater system and it plays all DVDs great. Maybe just a bad unit.
