WiFi booster
8ntw8tn
The new,small park we're in just installed WiFi. However,it's pretty weak even outside our trailer and usually unavailable inside most of the trailer. We do have an acceptable signal in the bedroom. I want to put a booster up there to make it accessible for the rest of the trailer. I'm looking at either the T-Mobile dap-1610 or the tp-link RE305. Both are really meant for home use and recommend having access to the router to press the button for the WP. That's not possible of course and the next recommendation is to use your cell phone and follow the instructions. Neither manual that I've downloaded explains that procedure. Before I spend $60 on either of these products I'd like to be sure I can set it up with the limited amount of technical knowledge I posess. Thanks.
'08 Chevy Silverado 3500 Duramax;
'10 Carriage Cameo F35FWS
Det 1 56th SOWg
11 REPLIES 11
YC_1
The Ubiquity product needed to solve the problem is less than $50 on Amazon.
You would need a local wi fi router to spread the signal throughout your rv and beyond. Or you can use any computer that has a cat 5 connection and then just share that via the computer.
The nano stations are easy enough to set up and I posted a link to an ongoing discussion in a previous post here.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
NamMedevac_70
Acampingwewillgo wrote:
"Visible" hot spot but join a group and pay 25.00 a month on the Verizon network! I keep this phone just as a back up to my T-Mobile phone/hot spot. I seem to always have good/usable signal on one or the other.
Maybe you can find someone like me with a grandfathered AT&T Mobley hotspot with true unlimited data and good reception to sell to you. Cost is around $23.00 per month and can use up to 5 devices. Besides travel I also use mine at home with AC adapter for internet backup. Good Hunting
jcpainter
docj wrote:
What you're actually looking for is a router/repeater that is capable of what is called WiFi as WAN which means that it can receive WiFi from a source, such as the RV park, and rebroadcast it inside your RV. Regular home routers don't usually have this function because you're unlikely to "drive" your house to where there's a WiFi to connect to!
There are a number of companies that offer routers with WiFi as WAN capability. You can read about this topic on the Mobile Internet Resource Center website. MIRC is run by good people who aren't affiliated with a specific manufacturer so you get good unbiased information. Some portion of the site is free; some requires a subscription.
MIRC
Joel (AKA docj)
Excellent advice to use MIRC for information!
Eric and Tami Johnson of Techno RV sell some decent units and they give service and support with their sales! I highly recommend them.
Matt_Colie
Well 8nt,
You can keep messing around if you want to, but doing the hotspot with Verizon hardware is so easy, that it makes everything else look silly.
If you really want to use the crampground WiFi, get serious and look up the Alfa units. Read about them. Before cell tethering was easy, I did this a lot. I often worked with spots I could not even see.
Now, I only use the Alfa hardware when cell coverage is so bad that it is an issue. (In spite of many believe, cell coverage is not universal all over the USA.) There are lots of dark places even if you combine coverages. I recently worked a closed Panera Bread.
If you are going to tether or hotspot from your phone, put it on a good power supply. This operation will toast the onboard battery. It takes about three keystrokes to set it up and which ever phone is hot, we can all (3) use it together.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
docj
MIRC
Joel (AKA docj)
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
8ntw8tn
I should have mentioned that I already have an unlimited data plan from Verizon for all the phones on my account. I'd just like to have decent wifi for my kindle and DW's iPad. Yeah, we can use the iPhones as hotspots, and probably will, just trying to avoid some of the hassle. And of course we have to have the wifi in order for the iPhones to update and do the backup functions. But we do have enough signal in the bedroom for that to happen. Thanks for the replies.
Det 1 56th SOWg
YC_1
Check out this current thread.
Simple device and you will get plenty of signal. Won't help with bandwidth of course but the signal should come in smoking hot. Make sure you are confident of the frequency band. 25. versus 5ghz for example.
Set this thing up, connect the cat 5 cable to a router of your choosing and you will have a nice umbrella around your rv.
H/R Endeavor 2008
8ntw8tn
Well, I have,at best, two bars of signal on my iPhone when outside the trailer or up in the bedroom. Once I get back into the living area I lose the WiFi signal entirely and the iPhone reverts to the LTE data plan. For some reason my kindle fire still picks up the WiFi signal even though it's not showing any bars at all;speed isn't an issue when it's connected. There are only a half dozen trailers in the park.
Det 1 56th SOWg
Acampingwewillg
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
agesilaus
Yeah even if you boost signal strength lack of bandwidth will make it useless. Most folks have given up on park WIFI. Think about a cell phone hotspot like the Visible $40/month unlimited.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Lwiddis
Are you sure your issue is signal strength? Could it be a lack of bandwidth?
