โJun-11-2017 04:36 PM
โJun-14-2017 03:00 PM
โJun-14-2017 01:34 PM
TheBearAK wrote:
I've pretty much given up on Linksys/Cisco home routers. I've been a network manager pretty much since the early days (token ring, RS-232, etc). I used to like the Linksys routers, but then started having lots of power supply issues with them. Then once Cisco stepped in and started putting their name on the Linksys, the quality seemed to drop.
For a long time I was pretty anti-DLINK because we went through a bunch of the DLINK hubs and routers that would just have a port go dead, but that seems to be a non-issue now. My current favorite for bang-for-the-buck is the Belkin routers. The AC1600 is what I've been buying for customers and have not had a single issue with any of them (more than 80 of them). And the range is really amazing considering these do not have external antennas. They are highly regarded in the gamer and hackers world because the CPU inside them is one of the fastest in a home router.
That said, it still would be good to connect via ethernet to the router you have and make sure there are no issues with the ISP. 100' CAT 5e or CAT6 ethernet cables are not that expensive.
โJun-14-2017 01:32 PM
jcpainter wrote:rhochnadel wrote:
I was told by AT&T they discontinued the mobley, would not hook it up any longer.
Whomever you spoke to was misinformed.
โJun-14-2017 01:14 PM
โJun-12-2017 06:47 AM
โJun-12-2017 03:30 AM
โJun-12-2017 02:38 AM
โJun-11-2017 08:53 PM
โJun-11-2017 08:48 PM
โJun-11-2017 08:47 PM
โJun-11-2017 07:52 PM
โJun-11-2017 07:50 PM
โJun-11-2017 07:15 PM
jch2122 wrote:jcpainter wrote:
What do you have in your RV to help with this?
Are you by chance in a good AT&T area? If so, you can get an unlimited Mobley for $20 a month.
I've never heard of that. Thanks for the info.
โJun-11-2017 06:23 PM
TheBearAK wrote:
First, which WiFi router do you have? Newer duel bands have a longer range.
A lot of different factors can go into why you're getting drops.
- How many other WiFi networks are visible in your spot? If more than just you own, make sure the channels are different from your neighbors. Modern routers should do this automatically, but neighbors might not have them and they can overlap and cause issues.
- Microwaves can interfere, specially in the 2.4 Ghz range. 2.4 Ghz is also widely used and other devices like land-line telephones (wireless kind) can interfere.
- Metal boxes, such as a motorhome can shield signals.
As for range extenders, I've never really had much luck with them. I've gotten them to work, but they were often slow and added a lot of lag.
naturist has a point, if you can just run a long ethernet cable around the house, that would be the best way of extending the network. Even if you just ran the ethernet cable from one side to the other and connected the extender. WiFi extenders usually have an ethernet port so you can use them as an Access Point.
