Win 8.1 to Win 7
ntar827
How do I remove Windows 8.1 and install Windows 7?
Some programs (expensive) will not run under Windows 8.
Thanks
Nick
7 REPLIES 7
kgarrett9999
Not really the solution that you asked about, but you could load one of the virtual machine systems such as Oracle's Virtualbox and run a Windows 7 virtual machine for the apps that absolutely need it and run Windows 8 for everything else.
strollin
There is no Win 7 emulation built-in to Win 8, it's possible the Technote was talking about Win 7 compatibility?
The page you linked to has nothing directly to do with Win 7 emulation. It's referring to Hyper-V which is a feature of Windows 8 that allows you to create and run virtual machines. A virtual machine is a fully functional machine but it is implemented entirely in software and runs as a program on your physical machine. With Hyper-V, you could create a virtual Windows 7 machine but you need to install Windows 7 from an install disk in order to do that.
Hyper-V isn't installed by default, it needs to be added via the "Turn Windows features on and off" function of "Programs and features".
Hyper-V requires you to be running 64-bit Win 8 Pro.
Me, her, 2 boys & 2 girls
'05 Chevy 2500HD LT 4x4, D/A
Reese Dual Cam HP
'04 Wilderness Advantage 290FLS
Twin Honda 2000s
"I'd rather wear out than rust out!"
See our pics here
docj
According to this Microsoft Tech Note, there is a Windows 7 emulation mode built into Windows 8 but I I can't find it in my Windows 8 Home edition. You can read about it here:
Windows 7 emulation
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
mileshuff
I have numerous programs that will not run under Windows 8. Most are specialized applications for industrial engineering use. Quite expensive to upgrade ($1000's) especially when little benefit is gained except for it running on new PC's. Also have several custom written applications. They won't run under Windows 8 because Microsoft changed several technologies they relied on. Microsoft has never thought backwards compatibility is something of importance. Their view is out with old technology, in with new, better gizmos. For me, I want reliability, stability, continuity etc but that doesn't get MS a constant money stream. My company has about 150 PC's, a few Windows 8, quite a few Windows 7, numerous XP, 2 Windows 98 and about a dozen running DOS...yes, DOS, all networked together.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
docj
Are you certain there isn't an update available for the programs you are concerned about? I've had no problems with Windows 8.1 with programs as old as Photoshop CS2.
Sandie & Joel
Tom_M1
Here's a link to a PC Magazine article: Downgrade to Win 7
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
sch911
Here is a decent video on how to do that.
What programs are you having problems with?
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
