โFeb-08-2021 12:46 PM
โFeb-09-2021 09:56 AM
โFeb-09-2021 08:38 AM
monkey44 wrote:
We use Ext Card readers ... and have not had trouble with access for years and years. Never have had a reader installed in laptop. Had one reader fail after a couple years - just bought another one, and back to work. In some cases, I trust an external plug-in more than internal. With internal, a hassle to repair or replace, but in the case of Ext card reader, just toss and get a new one.
โFeb-09-2021 08:15 AM
โFeb-09-2021 07:41 AM
wa8yxm wrote:
Just so you know my Win-10 box has an SD card slot in the side. it's part of the Computer not a USB device the CD-RW is a USB device, the Cassette Tape player is a USB device. the Big Ham Radio is Three USB devices. The Printer is a USB device ((You ask 3, on the radio Computer control. Push to talk and Audio))
There are more (the external half a terrabyte hard drive) but the SD card is a slot in the side of the computer..
Sometimes it does fail to see the card. other times it sees it straight off.
โFeb-09-2021 02:59 AM
โFeb-08-2021 06:46 PM
Kountryguy wrote:
Thanks Gdetrailer. Some of this is way above my pay grade, but I have tried the SD card in a different laptop and it works as I believe it should. The fact that the card works in the original laptop immediately after a restart is what has me confused.
โFeb-08-2021 06:15 PM
โFeb-08-2021 03:24 PM
dryfly wrote:Kountryguy wrote:
When I insert an SD card, it is not recognized. If I remove it, restart and reinsert it, it is recognized. Any thoughts on how to correct this problem?
Sounds like you are tying to hot swap the SD card, or flash drive (?). First thing to try is to go into computer's BIOS and makes sure that the SATA port the device is on has the hot swap feature enabled. All SATA ports hot swap feature are disabled by default on most factory BIOS settings.
โFeb-08-2021 01:06 PM
