Winegard Traveller Power requirements
LA48340
Installed a Winegard Traveller SWM-3 dish on our toy hauler. Would like to power it using an inverter when shore power is not available. Wondering what size inverter would be sufficient to power the 110V drive system power inserter. Have an inquiry into Winegard but wondered if anyone might have some experience with this set up. thanks
7 REPLIES 7
LA48340
Thank you for the very helpful feedback..
Bill_Satellite
big whitey wrote:
That said, in the interest of full disclosure my inverter comes directly off the battery and is located about a foot from the battery.
That's a very good idea!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
big_whitey
I run all 3 (TV,Winegard Traveler satellite,and receiver) with a 200W MSW Whistler inverter. I never unplug anything and use this set up exclusively as i am always off the grid as in boondocking. That said, in the interest of full disclosure my inverter comes directly off the battery and is located about a foot from the battery.
Tom_N
I raise and lower mine with a 300w inverter.
-Tom, W3TLN
Sarver, PA/Crystal River, FL/Shelocta, PA ยท W3TLN ยท FMCA 335149 ยท Mystic Knights of the Sea
2005 Suncruiser 38R ยท W24 chassis, no chassis mods needed ยท 2013 Honda Accord EX-L ยท 2008 Honda Odyssey EX-L
Bill_Satellite
Very small. It only needs power when going up and down and nothing after that. I believe the power supply requires 5 amps and runs at 48VDC.
However, you will need A/C power all the time to run the Power Inserter, the satellite receiver and the TV if not a DC TV. That's going to add to the power requirements. I found an inexpensive 750W which is over kill but I would stick with something in the 500W range if it was me. The small inverters tend to be noisy with their fan running so you might want to place it closer to the batteries and run A/C power line from there to where all the electronics will be.
donn0128
Once it has located the correct bird you can unplug it. So consumption is zero while watching TV. During setup a 1000 watt inverter is sufficient from what I remember.
sch911
The power consumption should be written right on the power brick.
OEM Auto Engineer- Embedded Software Team
