โMar-21-2017 12:33 AM
โJul-26-2017 03:35 AM
โJul-25-2017 07:16 PM
magicbus wrote:
I see what you mean about the one on Amazon, even has a different label printed on it than mine.
10 user model on Amazon
โJul-25-2017 07:10 PM
dcrv wrote:
Here's my Mobley. Paying $20/month with no contact for unlimited (22GB LTE, then throttled) in the car connected device plan. Paid $99 direct from AT&T online and had it literally next day with free shipping.
There was no way I was paying $25-$30 bucks for an AC adapter. Nope.
I'm tech savvy and decided to mod my own. I didn't want to make any mods that would make it unable to plug into the OBDII port, so I decided to simply open the unit up and tap into the power lines (pins 4 and 16) and solder on some leads and use a screw terminal barrel connector. This allows me to power the Mobe in three ways: 1.) Standard 12V AC wall adapter. Mine is 2.5A, but I would recommend at at least 1.5A. 2.) Battery pack. I can use a brick of 8 AA batteries or any sort of battery pack with a 5.5mm barrel. 3.) Vehicle 12V cigarette charger with a 5.5mm tip.
The newest firmware has a no timeout option, so I've been using it at home and work as well as in the car. Speeds aren't what I was expecting (likely due to no carrier aggregation), but still a hell of a deal for $20/month (and probably less than that since I will be using a discount code).
โJul-25-2017 01:35 PM
โJul-25-2017 11:43 AM
โJul-25-2017 11:38 AM
jcpainter wrote:
Mobleys ordered off of Amazon from a Canadian source do allow 10 connections.
โJul-25-2017 11:30 AM
โJul-25-2017 11:14 AM
โJul-25-2017 10:50 AM
lryrob9301 wrote:AMOS33 wrote:
My ZTE Mobley is the VM6200 updated with the latest firmware and can only connect 10 devices. But using the SIM card from AT&T, it works well enough for me.
I think if you check your Mobley you will find it can connect to only 5 devices at any one time.
โJul-24-2017 04:41 PM
โJul-24-2017 04:29 PM
โJul-24-2017 08:20 AM
โJul-24-2017 06:56 AM
โJul-23-2017 08:08 PM
โJul-23-2017 06:49 PM
