โApr-23-2017 02:37 AM
โMay-07-2017 09:43 AM
โApr-30-2017 01:47 PM
MEXICOWANDERER wrote:
Kudos dougrainer for excellent detective work.
Most pass through inverters use a sad printed circuit board DPDT relay. A separarte full size frame relay rated 30 amps like a GTE brand found on eBay is easy to wire and will outlast a circuit board relay 50 to 1. Enclose in a box. Use the normally closed contacts as the power pedestal circuit and the magnetic closed circuit for the inverter.
This is a fun project. I've done many of them to resurrect failed pass through perverters.
โApr-30-2017 08:35 AM
โApr-30-2017 06:22 AM
Roadpilot wrote:
You have a Magnum Dimensions 400 watt pure sine inverter. Input is +/- 12vdc and a chassis ground. Output appears to be via a normal wall plug.
Magnum has a trouble shooting procedure on their web site:
Trouble Shooting
I'd try that first. If it's dead they have a phone number in the trouble shooting page. Maybe they repair these?
If not I'd buy a 400-800 watt pure sine inverter woth a plug output and install in your failed units place.
Room should not be an issue because you unit is huge and it weighs 14 pounds. You'll be amazed at what will replace.
โApr-29-2017 04:07 PM
โApr-29-2017 08:32 AM
โApr-29-2017 06:39 AM
โApr-29-2017 01:29 AM
โApr-23-2017 04:54 PM
โApr-23-2017 10:28 AM
โApr-23-2017 10:21 AM
โApr-23-2017 10:03 AM
โApr-23-2017 08:54 AM
