Black Tank Dumping?
Only_True_Mosno
I recently traded my Cougar Fiver in on a new Montana 3721RL. When dumping my black and gray tanks on the Cougar it was obvious by the noise they were dumping. When I pulled my Black Tank handle for the first time on the new Montana I hear nothing? Gray Tank..same thing?
Here’s the strange part...
When I checked inside prior to dumping the black and the gray tank both registered 1/3 full. I did leave the black tank handle open when I went back inside and ran some water into the toilet. I went back outside and still nothing. The DW then yelled that the black and gray tanks were now reading zero fill. ?
I never did hear anything going through sewer hose, and the sewer hose didn’t have any residual liquid that I could tell left in it.
Only other thing I should mention is that this was the first camping weekend with the new rig and the temperatures dropped to a low of around 25 degrees overnight. Could this be part of the problem?
2018 Montana 3721RL
2018 Ford F350 Diesel
Life Comes Down to a Simple Choice...Get Busy Living or Get Busy Dying...
11 REPLIES 11
NHIrish
Sometimes the dump station has better suction than others...ditto on the clear elbow.
2016 Heartland Bighorn 3270RS
2010 Carriage Cameo 32-FwS
2008 Carriage Cameo
2006 Keystone Cougar
2005 Keystone Zeppelin
1999 Coachmen Catalina
2017 Ford F350 Powerstroke
Curt Q25
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
:W
bailer6334
FYI, its best if you dump your black tank when its 3/4 or full only.
That way you get rid of all the tanks contents and do not have a possibility of any residual buildup to clog the tank.
2017 Grand Design Imagine 2150RB
2016 Chevy 2500HD LT 6.6L DMAX 4WD
Equalizer 4 Point WDH
bukhrn
jwandvassie wrote:
Old-Biscuit wrote:
Next time dumping hold end of sewer hose up/out of sewer line and watch
OR better yet buy a clear adapter. Connect it between drain pipe and sewer hose. THEN you can watch the stuff flow.....no doubts and you can also see liquid clear up as you flush/rinse tank
X-4, I can see what's happening, regardless of what those ridiculous gages say.
+1
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
BizmarksMom
+1
+2
I do not always hear it when I dump the tanks. But I sure do see what's going through them.
2019 F350 towing a Nash 22H
Parrothead_Mike
I also use the clear adapter so I can see what's coming out of the tanks. (Kinda like watching the preverbal "stuff" go down hill.) I would also suggest that, if possible, run water from a hose or maybe even a near-full 5 gallon pail of water down the toilet. If you're still not seeing anything there is a serious problem with the valves. It's not like that has never happened, but quite unlikely.
2018 Chevy 2500HD Duramax - 2015 Cedar Creek Silverback 29RE
16K Huskey EZ Roller Hitch - EU2000i Honda Generator
Jim2007
Hi.. Agree with old-biscuit..
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
jwandvassie
+1
Dutch_12078
I don't normally hear much of anything when I dump, but I have a 45° clear elbow at the outlet that lets me see what's going on. Sometimes I can also see the hose bounce around a little when I first pull the handles.
Dutch
2001 GBM Landau 34' Class A
Old-Biscuit
Only_True_Mosno
Dumping
2018 Montana 3721RL
downtheroad
I'm confused (I often am)
Are you asking about "flushing" or about "dumping?" These are entirely different.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
