Nov-21-2017 04:39 PM
Nov-23-2017 08:49 AM
JWP127 wrote:
And what are your thoughts on a heat pump? Will LP suffice? I live in Texas and won't be camping in -1095644 degree weather too often, but we will winter camp at times. Will I burn thru LP tanks and my wallet, or is it manageable?
Nov-22-2017 10:21 PM
Nov-22-2017 10:18 PM
bikendan wrote:JWP127 wrote:
I called the salesman back. He confirmed there is no satellite hookup. And he was wrong, there is a hot water bypass.
In your first post, you said "technician" and now you say "saleman".
Which was he, cause if it was a salesman, its easier to understand his ignorance.
Nov-22-2017 06:32 PM
drsteve wrote:bikendan wrote:Terryallan wrote:
A first for me. I've never seen a TT with out a water heater bypass. Don't sound like a good plan. But IF you never use antifreeze. Not a big thing.
As for the electric jack. They are easily added, and you could prolly get one in the deal if they want to sell.
most of us have rubber roofs, Few have black tank washouts
totally agree.
never heard of any RV that had a water heater but no bypass. so i doubt if the RV tech knew what he was talking about.
i picked up a refurb electric jack on Ebay for $90. still working after 11 years.
I've owned a few RVs, and my most recent one is the first one ever that came from the factory with a bypass installed.
Nov-22-2017 04:38 PM
totally agree.
Nov-22-2017 02:18 PM
Nov-22-2017 12:56 PM
Nov-22-2017 08:55 AM
Nov-22-2017 08:48 AM
Nov-22-2017 08:18 AM
Nov-22-2017 08:11 AM
Nov-22-2017 07:43 AM
JWP127 wrote:coolmom42 wrote:
You do want a water heater bypass, unless you live somewhere that you don't need to winterize. Otherwise you will have to fill the water heater with antifreeze, before you get any antifreeze in the hot water lines. Aside from being a big waste of antifreeze, it's a PITA to get OUT of the water heater in the spring.
I thought so too until he showed me that you can drain the hot water heater, by removing a cap, and then opening up all the faucets and blow air into the pipes. Does this sound correct?
Nov-22-2017 07:35 AM
Nov-22-2017 04:18 AM
