โMay-01-2015 10:39 PM
โMay-06-2015 05:42 PM
โMay-06-2015 02:20 PM
โMay-06-2015 01:38 PM
GoPackGo wrote:
One thing to be aware of is that Suburban sells two different anode rods. One is made of magnesium and one is made of aluminum. The version that came installed in your water heater is the mag one. It deteriorates faster then the alum one and Suburban states to use the mag one as long as it lasts at least a year. I think it provides better protection because it breaks down faster. They look about the same and when shopping for a replacement, you have to read the packaging closely to see which one you've got.
I've also seen the ones at CW that have the built-in drain valve. As I recall, the anode itself is made of aluminum and is also fairly short.
I personally will only use the mag ones. I WANT them to deteriorate at a good rate. I'm just a little uncomfortable about using the aluminum version.
FWIW, all the non-Suburban anode rods I've seen at CW seem to be made of aluminum.
My .02
Tim
โMay-06-2015 12:49 PM
โMay-06-2015 12:27 PM
โMay-05-2015 12:51 PM
path1 wrote:
For another non RV project I reduced my wet/dry hose size using clamps and vinyl tubes to get out water out of a real small place.
When changing my anode I thought about sucking out the water out of the bottom of hot water tank and then letting it dry out, then put anode back in. My thinking was no water, no rust. Then I think about a hollow steel container would just slow down the process and not be worth the hassle.
Wonder why you can get propane tanks made of fiberglass and not hot water heaters?
โMay-05-2015 11:47 AM
โMay-05-2015 09:02 AM
Wishbone51 wrote:
I don't know if I'm doing anything majorly wrong, but I use no attachment when flushing out the water heater. I hold the hose to the opening, let it run for 20 seconds, let go and it whooshes out. I can stick my finger in and feel all the sediment on the bottom. Once I can feel no sediment, I'm done. Am I missing anything by not using the flushing attachment?
โMay-05-2015 08:43 AM
โMay-05-2015 06:38 AM
โMay-05-2015 06:09 AM
path1 wrote:
Changed anode out yesterday.
Thanks for all the help.
And don't lose your tank flusher thing like I did (temporally I hope). I picked up another but the only replacement CW had was ($6.50) for one with a pex tube instead of a metal tube like my old one. Pex tube tries to lift up and get away with water pressure.
โMay-04-2015 07:31 PM
โMay-04-2015 04:07 PM
โMay-04-2015 09:32 AM
