โFeb-06-2015 07:03 PM
โFeb-13-2015 04:11 AM
handye9 wrote:Mine on the other hand, was only 8 lbs over its published brochure weight before propane and battery. So I guess the point would be, go to the dealer and look at the model in question and get the weights as it sits there right on the lot - before you buy. No need to speculate that way.2014screw wrote:
Are the hitch weights on a manufacturers website only "Dry" weights
No battery & empty propane bottles?
Not only, do they not include battery and propane, they also, do not include many options. They are marketing numbers, normally from a basic model....
โFeb-12-2015 07:15 PM
โFeb-12-2015 04:08 PM
โFeb-12-2015 03:52 PM
Allworth wrote:
Just tell us where you are going to be so we can avoid those roads!
โFeb-12-2015 08:49 AM
โFeb-12-2015 08:25 AM
โFeb-11-2015 06:20 AM
Bobbyg2013 wrote:
IN YOUR FORMULA, WHAT DOES THE * SIGN REPRESENT, I.E. max gvwr of TRAILER/100*10=TONGUE WEIGHT
โFeb-11-2015 06:18 AM
โFeb-10-2015 10:16 PM
cdevidal wrote:
True, but some people can't go with more TV or less TT. I'm one of those; It's a long story why. I think we'll be alright, as we're not actually over any ratings, and I've included safety buffers to boot.
โFeb-10-2015 06:13 PM
โFeb-08-2015 04:31 AM
โFeb-07-2015 10:52 PM
cdevidal wrote:
There is some good news though, since you're butting up against the payload rating like I am. A weight distribution hitch, if you use one, will transfer anywhere from 20-30% of the tongue weight to the trailer's axles. Since I am planning conservatively, I calculated 20%.
So my formula looks like this:
Trailer weight loaded (max GVWR) / 100 * 10 = Tongue weight
Tongue weight / 100 * 80 = Final tongue weight on the vehicle
I forgot to mention, you also need to add the hitch weight to your vehicle's load, since most of the weight from the hitch, except the chain mounts/snap-ups, is on the vehicle. So every pound saved on your hitch goes a long way. If you have a lighter vehicle, the Andersen hitch is a good choice, at less than 60lbs. So is a Harbor Freight hitch. There are pros and cons to these hitches though; I encourage you to read the forum threads on this item before making that decision.
Be forewarned though, asking which hitch is best is kinda like a religious debate, or Packers vs Patriots vs Seahawks ๐
Any actual experience with a Harbor Freight WDH?
Anderson Hitch
Harbor Freight hitches use a friction device, so read this too:
Friction anti-sway device use in rain or wet roads
โFeb-07-2015 07:26 PM
โFeb-07-2015 07:21 PM
