Replacing Converter
er78mph
Hello and thanks to all in advance,
I found out that the stock converters are slow chargers and could possible damage the batteries so I want to replace mine. I was looking at one on Amazon and will put the specs of both the old and the new down below. My current set up seems like is an entire panel, could I just wire the new converter in? The process seems straight forward but I've done to many DIY's to know better. I was looking at tenders but for a few more bucks I could get a converter. Seems more practical. Thanks
Current Converter
Parallax
7355, 55 Amp DC, All in one converter charger, main and 5, NO TC
New
Powermax 110 Volt to 12 Volt DC Power Supply Converter Charger for Rv Pm3-55 (55 Amp)
10 REPLIES 10
Bobbo
CharlesinGA wrote:
Progressive Dynamics PD4355 would be a direct replacement for what you have. Disconnect battery ground, unplug shore power, turn off generator, open front panel, remove screws and fully remove front panel, remove some wires (mark first) and some screws, slide out old converter, slide in new. Replacing the fuse panel with the new one is a little work, and if you are picky and want to do a neat job you may end up rerouting a wire or two for a better routing and fit, but it comes with a new housing for the converter, so the swap is quite easy. Just went thru this a couple of months ago.
http://www.bestconverter.com/4600-series-Upgrade-Kits_c_133.html
BestcConverter is a family operation and if you have an issue, they will talk to you evenings, weekends, whenever you need help.
Charles
I did this replacement, PD4655 for a Parallax 7345, in 2011. Still well pleased with the result.
At the same time, I upgraded the 8g wires going from the converter to the battery with 4g wires. That was to reduce the voltage drop.
Note that in the quote above, the PD4355 is a typo. It is the PD4655.
Bobbo and Lin
tenbear
Good advice. I replaced my Parallax with the PD9260. Very reliable and much faster charging.
2010 Subaru Impreza Sedan
CharlesinGA
Forgot to add that the Progressive Dynamics converter is a multi-stage unit that charges at a higher voltage when the batteries are low, and as they peak the converter drops back to a more reasonable voltage for topping the batteries. It also has a desulfator mode that happens only ever 21 hrs or something like that. It has an indicator LED that flashes to show what mode it is in, and a push button to force it into certain modes, and the new 12v fuse panel has two more fuses, plus fuses for protection from reverse current, plus warning LEDs to show when a fuse is blown.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
CharlesinGA
Charles
time2roll
Don't get Boondocker for generator charging. Get Progressive Dynamics or IOTA.
Boondocker drops out of boost at about 70% charge then you are back to the trickle charge. Boondocker is fine if you are plugged in with lots of time.
tvman44
Look into Progressive.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Dutch_12078
Best Converter does carry the Powermax line, and currently lists the newer PM4 series instead of the PM3 you found on Amazon. I have a Powermax PM4-45, and I've been very pleased with the performance.
Dutch
2001 GBM Landau 34' Class A
RoyB
However..... Don't let Randy talk you into a WFCO product...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
bob213
X2 What TucsonJim said. Randy(Best Converters) may not have the "very" cheapest price but he will walk you thru any problems. Great customer service.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
TucsonJim
Please do yourself a favor and call the guys I'm linking to below. They can give you great answers and you won't be relying on opinions in an internet forum.
Best Converters
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
