WiFi - one computer at a time - common?
dbwiddis
Parked at a campsite on our very first RV trip as a family! Yay!
We got an access code for the wifi (Tengo Internet) but each different computer that wants to use it has to "take over" the connection, so we can't all be online at the same time.
Is this normal/common for campsites? What do most people do who want to use a router or somesuch to share access?
33 REPLIES 33
Ron3rd
Ditto on the router. Essentially, all computers "hide" behind the router and the ISP only sees the IP of the router.
Equilizer Hitch
Honda EU2000
1775
We regularly go to a campground that uses Tengo Internet as their provider for wifi. We have never had the problem that you describe. We both have been on laptops on the wifi at the same time at that campground. This may be something that just this campground has set up. When I have used Tengo at a campground, when the laptop or tablet is first turned on to wifi and a browser is started, it starts on the Tengo home page where it asks you to register a login id and password. Once that is put in, the page opens to another home page that includes the campground's name and asks how many days are you staying. I always select the maximum choice and the login that I registered is good for that long - and can be used by any computer or tablet that we have at the same time. And if one wanted, each could "set up an account" with their own id and password. Once you log in for the first time for the stay, you get another welcome page that says it is free. (they don't ask for any personal information or billing information)
It is odd for a campground to use a different code for each RV/TT that comes in. In campgrounds that we have been to where they give you a code, the code is the same for everyone.
We have had minor problems with campground wifi. So far I have not seen a need to pay for a data plan for a hotspot connection. We are good to check email, browse the web, etc.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
dodge_guy
We went to a Jellystone and they gave me one code. Only worked on one device! I went back and said i needed 6 more numbers!!!!!! I got them, but they were useless as you could barely get a connection. Tengo internet is not very good!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
NorCal_Dan
Not sure about M$ OS but OSX will allow sharing an internet connection but you must have 2 wifi devices on the Mac. I use my Airport Extreme to "share" the connection from my iMac so we only need one code. With multiple devices that need internet access using this setup means I don't have to re-engineer all my devices when we move...I just get my iMac online and all the other devices do not need to be modified, they still get their connection from the airport extreme.
'13 Ram 2500Hemi pulling '12 Coachman Chaparral -- USAF Retired --
rvten
I use a WiFi Ranger router with a VZ usb card.
But the router will boost the CG signal if I want to use there service.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
wa8yxm
rvten wrote:
Usually just the ones you have to pay for.
Most CG/RV parks with FREE WiFi you can run more than one device on the system.
I will second that, If you need to log on with a user name and password it usually is one to a customer.
Of course.. I cheat.. In many cases I can log on my Wi-Fi modem and let it re-route to all my devices but alas, they don't make that modem any more.
wbwood
Acampingwewillgo wrote:
I've seen some CG's with Tengo-Net that will give you more than one access code.....maybe your place will too????
Ditto. The KOA in Wilmington nc uses tengo. They ask us at check in how many devices. If we tell them three, then they give us 3 codes.
Brian
2013 Thor Chateau 31L
Pepperoni
dbwiddis wrote:
And the office is closed now so can't get another code until tomorrow. Not a big deal, just trying to learn from experiences and see what we need the next time.
You may want to try running a router. Cradlepoint comes to mind. Runs off 12v, will hold multiple card types and will handle multiple pcs while appearing as a single IP.
Dutch_12078
SCVJeff wrote:
Someone has likely done it here, but I think if you were to add a router/ repeater where you sign on through it, the host sees only one MAC address and you might be able to get around it.
Yep, the "PayFi" TOS usually says something to the effect, "Only one device may connect using each code.", but if that "one device" is a router/WiFi repeater like some models from Cradlepoint, Pepwave, and others, then multiple other devices can in turn connect to that "one device". Legal? Probably... Circumvents the spirit of the TOS? No doubt...
Dutch
2001 GBM Landau 34' Class A
SCVJeff
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
Altern
sch911 wrote:
Normal. Your access code allows only one connection.
X2.
Think of it from their side. You could set up shop from your computer and start selling Tengo Net's wifi to others.
I carry the MIFI also.... But we camped at several places this year that offered those codes from Tango... They asked us how many computers we had , and how many codes we wanted....our MIFI plan was getting to the upper limits , so we went with the codes... Joe
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
HappyKayakers
Common for Tengo. You're being charged for a single device. Verizon MiFi would be a good choice for you if you're going to travel frequently.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
sch911
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
dbwiddis
