ac unit keeps tripping breaker
Joejax
All of a sudden my ac trips its breaker as soon as I turn it on. I'm plugged into a good 30 amp service. I've turned off all other breakers and still no luck. Installed new breaker and checked wires....no luck. Never had any problems before? So now its time climb up onto the roof. Anything I should look for? Thanks
5 REPLIES 5
Joejax
Great news: yup it was a loose micro board in the junction box. It actually was arcing to the box. Black wire. Easy fix and thanks so much for the replys that probably saved me huge $$ if I were to take it into a shop.
Joejax
Fan runs no problem. Only when cool is turned on and its immediately tripped. It makes a makes a quick buzzing sound at the breaker then "pop"
Chris_Bryant
If it trips the breaker the instant you call for cooling, it almost has to be either a short in the wiring, a shorted capacitor, or a bad compressor.
If it runs for a bit, look at the condenser (outside) coils and the fan blades.
-- Chris Bryant
Mich_F
Many years ago I had the same issue with a new travel trailer. I don't remember how many times or places I had used the air conditioning without issues before hooking up to one park's power only to blow the park's post circuit breaker immediately. Got the park ranger to come out assuming there was something wrong with the park power, since I had a new trailer and figured my trailer couldn't have been the problem. Naturally the park power was fine and they actually had a GFCI wired into the pedestal. After turning off different circuit breakers in the trailer we narrowed it down to being the air conditioner that was causing the problem. When we got home and took the inside housing down we discovered one wire had a bare spot that was grounding out on the metal frame of the electrical box in the unit. It had been wired that way when they installed the AC at the factory.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
Old-Biscuit
Start capacitors.....fan and compressor. Especially compressor.
Bulging/leaking
Does fan run.....t-stat fan ON ?
Compressor motor could be bad
