advice needed on cleaning rubber slide-out seals
3Fivers51
While washing our camper today we have noticed what appears to be "mold" spots/areas on the seals on top of the slide-outs. We have noticed it in past years and were able to clean it somewhat at those times but this year has been noticeably worse. We have had a wet, cool spring in MN and now is hot and dry. We did winter in FL this past year also. This year we are having a hard time removing those areas and do not want to use anything that will harm the surface of the seals. Any suggestions out there?
4 REPLIES 4
Chuck_Gail
I rub my seals with 303 Protectorant. It cleans them while also making them very flexable. I do it ever spring, and sometimes in fall before storing.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
Metaphor_7182
Consider a dilute solution of Oxyclean. Works well on moss/mold issues in the PNW. Rinse well off the painted surface and apply a quality wax.
mlts22
Rubber in slide seals is just like the rubber in tires, in the fact that it rots and crumbles. Every 5-6 years, it is good to completely replace them if at all possible.
1492
Moderator
Moderator
Moved from Forum Technical Support
