Any E rated tire in 205/75/14 or heaviest available.
ulvik
I wanted to change out my wheels and tires to a 15" heavy duty wheel and tire but found out I don't have room to do so without a ton of work and welding to move one of my axels back because I have a Dexter axel on my TT. With that being said what is the heaviest duty 205/75/14 or 215/75/14 inch tire I can get for my trailer. I currently have a load range C tire with a max load range of 1750LBS. I would like to get above 2400LBS with as many ply's as possible.
2018 Ram 3500 DRW
2015 Heartland Big Country 3650RL
Great Smokey Mountains
18 REPLIES 18
Tom_Trostel
Maxxis Bravo UE 168 and Hankook has switched to RA 18 model
maxxis
Dannyabear1
Hankook RA08 , a true D rated tire , over 2100# capacity, 99 mph, 8 ply; you will have to order online probably, mine came from busdepot.com. $500 for 4 shipped, and you only need 195R14
Wills6_4_Hemi
I believe maxxis has an 8 ply D rated tire that size
Sam_Spade
There is no good reason to increase the size of the tires and rims.
A quick Google search shows that 215/75/14 is readily available in load range E.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
