โApr-19-2016 04:47 PM
โApr-21-2016 07:04 PM
WTP-GC wrote:
Reading this thread further validates that the internet has created more mis-placed worry in people than God ever intended. Just remember, in the daylight you will cast a shadow...and it's not going to hurt you.
โApr-21-2016 05:54 PM
โApr-21-2016 05:34 PM
โApr-21-2016 05:15 PM
Cummins12V98 wrote:
Plain and simple they over torque because it's faster!
โApr-21-2016 04:42 PM
โApr-21-2016 12:42 PM
dave54 wrote:westend wrote:
I'm sorry but this is another jab at workers and it's getting pretty old to me. Is this the type of behavior that you do in the workplace, change your ethics, procedures, and work pace when not directly under supervision?
FWIW, I've worked in some shops where the employees were on a higher road and showed better customer appreciation than management. /rant..
The conscientious workers promote faster, the total slack offs do not last long at all. So the odds favor you will have a younger worker with marginal skills and average work ethic.
โApr-21-2016 10:29 AM
โApr-21-2016 09:59 AM
dave54 wrote:Durb wrote:
When you get home, loosen each nut one at a time and re-torque...
One at a time does not work if you three step your torque, as recommended in my owners manual. All have to be loose to start.
Agree about the tire shops. The manager/shop foreman may be as knowledgeable and experienced as they come, but he will not be the one in the back doing the work. It will most likely be some young fresh out of high school kid doing tire changes. He probably was trained the right way, but uses shortcuts and sloppy procedures when the boss is not looking.
โApr-21-2016 08:31 AM
โApr-21-2016 07:27 AM
Cummins12V98 wrote:Durb wrote:
Sold torque wrenches for 30 years and have performed extensive training to industrial end users regarding the correct way to use a torque wrench. Once a wrench clicks it is now a breaker bar and can be used to over torque the lug nut. A major tire chain I know examined their installers' technique and found they were tightening the lug nuts up to 200 ft-lb over the spec. Torque sticks are ok for pre-torqueing fasteners but final torque should be done with a torque wrench. I can guarantee that almost all tires installed at a shop have over torqued fasteners due to poor technique.
When you get home, loosen each nut one at a time and re-torque. Pull slowly on the wrench (don't push) and when it clicks stop. Make sure you chock your tires, any torque used to rock your rig is coming from your lug nut which will be under torqued.
Good OL LesSchwab is great for rattling the lugs up then hit the lugs with a torque wrench, the sad part is each lug is already over torqued since the torque wrench clicks at each lug with out lug movement.
One thing I would do different than you is I would loosen all nuts about 1/8-1/4 turn then properly torque to spec.
โApr-21-2016 07:03 AM
WTP-GC wrote:The other side of the coin is that it has helped with the proliferation of mis-information about the smart thing to do too.
โApr-21-2016 06:52 AM
โApr-21-2016 03:27 AM
