1L243
Jul 07, 2019Explorer II
Axle Weight
Should combined axle weight be greater than rated GVW? In my case my axles are rated at 4400(x2) 8800 and my GVW is 9680.
wa8yxm wrote:
THat sounds like a good design to me (Combined axle weight greater than max vehicle weight) Gives you a bit more flexibility in loading the rig.
I'd be worried if the combined axle weight was LESS.
rk911 wrote:DrewE wrote:
...For a car or truck or motorhome, the sum of the axle weight ratings should not be less than the GVWR. Often but not always they will be higher, giving some flexibility in weight balance when loading to the maximum rated load.
I've seen up to a 500-lb difference between the GVWR and sum of the GAWRs on a MH. the difference is almost always the max tongue weight.
ppine wrote:
What happens when you park the trailer and disconnect it from your Tow Vehicle ? Then your exceeding the GVW for sure.
