On the Ford SD 6 3/4 bed, the axle center is about 41 inches back from cab. I would stay at least 40"s behind cab, with the arms back, at least until you figure out backing clearance issues. I have no problem with pin center 40"s behind cab, but every trailer will be different.
Yes, if you back/twist tight enough, you will at some point hit the cab.
Jerry
