Bathroom roof vent
daddyzaring
I am needing to replace the fan blade in our bathroom roof vent.  I was wonder is there any way to add a small 12v light, or do they make anything like that?  It is right above the shower, which isn't very well lit.  I'm hoping for some ideas on what to use.  This is in a 1993 35' Fleetwood Terry.
4 REPLIES 4
opnspaces
Navigator II
Navigator II
I always look at Tweety's RV for these kinds of things. Is this what you're looking for? If not just go to the top of the web page and type Fan Blade into the search box and see if what you are looking for comes up.
Link
On Edit: Looks like this is for a stove top vent. But the suggestion of following the link and typing Fan Blade into the search might still yield what you need.
StirCrazy
Moderator
Moderator
yes, you can, you just have to look for the right fixture.  HERE  is one I found on amazon.  or you could always go the DIY route and just add some led lights to what ever fan you replace it with if your handy
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
I am not really wanting to replace the whole vent.  It is just a little 2-3 inch blade, and a motor with the wiring.
ok then the second part of my statment, just replace it and add a led board to it with a switch of some sort.  I was lookign at the others because that little 3 blade fan that covers 1/5th of your skylight barrly pulls a fart out of the bathroom and certianly doesnt make air flow, so I was going to replac emine with the other kind so I can use it to help cool down the camper.  when you mentioned lights, I started to wonder if they had them with built in lights..
2016 Cougar 330RBK
