Battery for electric tongue jack
Copper_Penny
this might be a silly question to some but if I add an electric tongue jack to my tt is the one battery I have good enough or should I add a second battery.
I will be hard wiring it in, not the one with the 7 pin plug.
Denis, Linda, Jennifer & Monte (Shih-Poo)
2010 Ford F-150 Lariat,6.5'box,4WD,5.4L, Max tow package,3.73 Gears,11,100 tow capacity.
2007 Kodiak 21QS Queen Bed solid rear slide,4000lbs,gvwr 6000lbs
Husky Weight Distribution Hitch.
8 REPLIES 8
Copper_Penny
thanks guys, appreciate it.
wa8yxm
The photo above is.. by the definition of battery,, ONE BATTERY. And yes that is enough.
The little AGM I use to run a fan when I build a campfire is also ONE BATTERY, and its not enough.
But I'd say anything larger than a group 24 Marine/Deep cycle should be enough.
By the time you get to Group 31 you can drop the Marine and go with just Deep cycle..
NOTE: I tend to go at least one size bigger than needed.
4aSong
downtheroad wrote:
I run this setup for my Atwood tongue jack...
Seriously, you are good to go with one. (healthy batt).
:B :B :B :B :B
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
wa8yxm
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
nomad297
You are good to go with what you have. Make sure you install the correct fuse.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
midnightsadie
make sure you put a inline fuse. my daughter has one on her utility trailer uses it weekly only charges the battery twice thru the summer.
fla-gypsy
One battery in good condition is enough to handle a Tongue Jack. If you are using shore power also you have nothing to be concerned about.
