Black tank plumbing question
Skipg
I know I have a black water vent on the top of the roof of the MH . Why do I also have an AAV (air admittance valve) under the bathroom sink? Aren't. they used for the same function? I'm confused.
2 REPLIES 2
Bobbo
Almost right. The AAV under the sink, on either the black tank or the gray tank, vents the sink's drain pipe after the P trap. If it wasn't there, as the water drained out of the drain pipe into the waste tank, it would pull a vacuum that would suck the water out of the P trap, allowing the tank fumes to come up through the sink drain.
Bobbo and Lin
harold1946
The AAV is for the grey water tank, to help prevent the backflow of fumes through the P-trap.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
