โJan-30-2015 12:23 PM
โFeb-08-2015 06:40 PM
icanon wrote:kennyzzz wrote:
some reading for you, hope it helps.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25572537.cfm
ps it helps if you tell what you tow with.
ps # just trying to help
Thanks I'm reading this link now.
Towing with a Dodge Ram Laramie 1500 Quad cab 5.7 Hemi with 3.92 diff. with 4 corner air suspension. My new trailer in which I'll be picking up this spring is a Kodiak 290BHSL with a unloaded TT of 6,005lbs and a TW of 781 lbs.
Assuming I load it to the max load of 1,500lbs therefore I'll be around 7,500lbs but the TW is were I'm trying to respect to a max of 960. After reading many blogs and forums about whether or not to install a WD and/or Sway control has me wondering what route to go? I believe and my thoughts that there is no harm in installing a system like equalizer only to benefit if there is any, any problems that can occur out on the road.
Thanks for the reply. Will update my signature to reflect my rig ๐
โFeb-01-2015 05:14 AM
โJan-31-2015 03:30 PM
BarneyS wrote:
Welcome to the forums! ๐
Your signature will only appear once on each page. After the first post on a page you will not see it on next posts on the same page. On the next page, if you make another post, it will appear again.
Barney
โJan-31-2015 02:36 PM
โJan-31-2015 02:23 PM
โJan-31-2015 11:55 AM
icanon wrote:
Thanks Handye9
Nice little video. Now which one Equalizer or Blue Oz? :h. ๐
โJan-31-2015 11:38 AM
โJan-31-2015 11:32 AM
โJan-31-2015 11:09 AM
โJan-31-2015 05:20 AM
โJan-30-2015 06:26 PM
