Can a quadriplegic driver handle braking-Class A gas/Class C
COCO2009
We are looking at buying a Class A gas or Class C motor home,wheelchair accessible, and capable of towing a minivan.
My question is can a high-functioning quadriplegic handle braking with hand controls without a problem? My brother-in-law thinks we should add air brakes if my husband (the quad)drives with hand controls. We would have all the usual braking systems in place including on the toad (planning to tow four down).
Any thoughts?
Thanks
18 REPLIES 18
Rough_nit
I am a high functioning quad(C6-7). We have a 36' Southwind A that we had modified. Actually widened the original entry door with a 30". Wider door fit with no cabinet mods inside. We added a Braun under vehicle lift. It is not the typical way to modify but we wanted to avoid a second door for the lift.
Braking with hand controls is no problem. I found the steering at low speed a bit difficult. Parking, maneuvering, etc. We had reduced effort steering installed which worked out great.
I've driven full size and mini vans with no steering mods.
I don't have any visibility issues. The mirrors and the rear camera are fine for me.
Rough'nit
silvercorvette
I am guessing the one of the biggest problems will be moving around to get a better look at the mirrors when the driver needs to maneuver, in addition to the need for the driver to move their head shifting the body around for a better view is also necessary.
2014 4 WD Silverado 403 CI diesel long bed dually, B&W hitch with 95 Gallon Auxiliary Fuel Tank, pulling a 33 foot Holiday Rambler Alumascape suite, Winegard SK-3005 TRAV'LER slimline dish, Splendide 2100 XC washer dryer, TST Tire Pressure monitor system.
thestoloffs
Sorry, Brian, from a rehabilitation professional's perspective, we'll have to agree to disagree.
To the OP's question, if he is having difficulty operating the gas &/or brake pedals due to his condition, then this is sufficient.
Whether it's an air brake or air over hydraulic brakes doesn't matter; what does matter is if he can operate the pedals with reduced force sufficient to slow / stop the vehicle.
wny_pat1
thestoloffs wrote:
VintageRacer wrote:
You can't "add" air brakes, the vehicle either has them or doesn't. But they don't require a significantly different effort than any other brakes.
Sorry, Brian, I hate to disagree slightly, but Wells-Engberg makes a pneumatic hand control which uses a compressor to activate air cylinders to depress the accelerator and brake pedals proportionally to the level of effort applied. (We have this on my wife's Astro van, using a set of pedal switches originally designed for use by little people. It's very delicate.
But that is not air brakes in the sense of what a RVer thinks of as air brakes. That would be more like air over hydraulic brakes.
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
thestoloffs
COCO2009, if your husband requires such controls, your local NMEDA van modifier can install them, in addition to any other extra mirrors, "zero effort" power steering, electric parking brake, spinner knobs, etc. If you think the "air" system is necessary, a local SCI center may have a driving evaluation service available, that could also make recommendations and even write prescriptions (for insurance coverage, if any).
By the way, we have one of the Born Free Class C's without the step down which Tony & Karen referenced in their reply. Ours isn't set for DW to drive, but the front half floorplan can easily be reversed to provide the clear space for him to access the driver's seat.
Another suggestion: if your husband has difficulty turning his head / neck to view outside mirrors, you might want to consider a triple rear-view camera system (left & right sides, rear), like the bigger Class A's use.
tonyandkaren
Welcome to the forums COCO2009! Tony and I have been fulltiming since 1993. A few months after we started I was in an accident and am now a paraplegic. I haven't driven since the accident although I know I should so I think that it's great that your husband will be driving the RV. I can't offer any advice about that but I do have some about actually buying a RV. A class A would probably be better than a C because most Cs have a step down to the driver and passenger seating. If you do decide on a class C Born Free makes accessible custom class Cs that don't have the step.
Check out my blog - link below. I post short reports about wheelchair accessibility at all of the places that we visit.
Good luck with your plans!
Our Fulltiming Blog
Clickable Attractions Maps
4x4 Custom Class C on F450 chassis
COCO2009
Francesca Knowles: problem is years ago my husband and his dad started a mobility business, then my husband got a master's in engineering. No longer have the mobility business, but my husband would probably do it himself with help from friends. He modified a Braun lift for our minivan and built his own electric chair. Never thought about the insurance issue--will have to check. I have always been the one to question safety--have to think about myself and others on the road--he usually listens.
COCO2009
Ya I know--in my case I get to listen to NPR--which gets a little tiring. LOL
Francesca_Knowl
COCO2009 wrote:
Mostly because my husband insists on driving and being super-independent 36 years post-injury (hang-gliding) which is great most of the time but adds a lot to my worries and stress--you would think I would be used to it by now! Thanks though--and my husband does not like my driving!
I get it...
You know, it might be worthwhile to ask the folks who'll be doing the hand control mods what they think about adding air brakes. Presumably, since they're specialist they'd know what to advise for safest operation.
You insurance company might have an opinion, too.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Steve_Martin
He who drives controls the radio; therefore, I drive! ๐Ÿ™‚
COCO2009
traveylin
Ditto the above post, My DW is para 100% right and 70% left and drives a car just fine. The motor home is a larger job and I find it just a whole lot simpler if I do the driving. Out west where its many miles between lane changes she will occasionally drive the MH with toad to gather some practice useful in an emergency. We also limit the days on road time to 5 hours or less which is suitable for this retired driver
Francesca_Knowl
Any thoughts?
Thanks
Would it be indelicate to inquire why your husband is doing the driving?
I have some inlaws in a similar situation, and in their case they solved a lot of logistics problems by simply having the wife drive the moho. (The van is already equipped with hand controls, so Hubby drives that when they're out-and-about)
Golden_HVAC
If you can drive a E-350 Ford van with those power brakes and gas controls, the E-350/450 minimotorhome and F-53 motorhome (class A) use the same power steering, and other controls.
I think one of the modifications is to raise the power steering pressure, so it turns with less feedback, but is really easy to turn, and might even lessen the power braking effort required.
Before making the final decision on a RV, you might want to get the controls company involved that installed the hand controls on your minivan. They might say that any E-450 based motorhome will use the same controls as the E-150 and E-350 full sized vans, straight off the shelf parts. Those some controls might fit on a class A and might not. It depends. My motorhome is a 97F-53 chassis, same as the Ford van steering wheel of that model year, same chassis as the F-450 truck of that model year.
Raising the power steering pressure should be the same as the F-350 van. They do this so you can steer with one hand, and use the other hand on the brake / gas lever. (some reading this might not have driven a handcontrolled van).
Try looking on RvSearch.com for a RV with handicap access. Sometimes I see them.
I have also been typing in Handicap to the "For Sale"section of my local Craigslist.com and sometimes a motorhome will show up.
Check with Roadmasterinc.com for possible baseplates for your minivan. If the van based motorhome is short enough, it might mean taking along the minivan is redundant.
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
