Can you tow a 2019 Honda Civic Sadan manual trans 4 down?
joe_julie81
Motor Home Magazine shows that the Civic coupe, and Hatchback Sport, manuals, are towable 4 down. The very rare 4door sadans have the same 6spd manual transmission. Does anyone have a 4door 2019, or close, Civic that you're towing 4 down?
04 Dodge 3500 dually, HO CTD, 6 spd NV5600, 4.10 anti-spin rear axle; 2018 NorthStar 950sc with 320 solar, sub-zero package, compressor fridge, torklift tie downs
6 REPLIES 6
joe_julie81
Excellent, Ed, my son is actually taking delivery on a new 2019 Civic sadan 6spd tomorrow. I'll check in his owners' manual to confirm it matches what you posted. I feel sure it will. I knew an automatic and cvt were out of the question. I'm hoping someone is out there using one this wau with some miles of proof behind them. Thanks
Ed_Gee
I found the definitive word from Honda in their 2019 6 speed Jan 2019 Owners Manual:
....and it wasn't easy ! .....
Honda
Towing Behind A Motorhome
Models with continuously variable transmission
Your vehicle is not designed to be towed behind a motorhome. If your vehicle needs to be towed in an emergency, refer to Emergency Towing.
Improper towing such as towing behind a motorhome or other motor vehicle can damage the transmission.
Models with manual transmission
Your vehicle can be towed behind a motorhome. Perform the following procedure before towing your vehicle:
Shift to Neutral.
Release the parking brake.
Turn the ignition switch (or power mode) to ACCESSORY. Make sure the steering wheel does not lock.
Turn off all electrical devices. Do not use any accessory power sockets. This can prevent the battery from running down.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Ed_Gee
enblethen wrote:
What does the owner's manual say?
Page 431 says no recreational towing.
2019 Owner's manual
That is not the manual for the 6 speed turbo manual transmission.....
Scion xA toad
2oldman
Your sedan owner's manual should have that.
enblethen
2019 Owner's manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Ed_Gee
According to the Good Sam tow guide, yes.Good Sam 2019 dinghy tow guide
Scion xA toad
