charging battery on toad
MegB
I tow a Matrix and am wondering if it makes sense to use a battery charger to keep it charged along the way. It has to be set on ACC for it to be towed and the battery dies after a few days. I have had some luck running it each night for 10-15 mins. and/or unhooking and driving it after a few days of towing,but want to avoid all that. I was reading about the NOCO Genius chargers but am still confused about which one I'd need. Thanks,Meg
17 REPLIES 17
WyoTraveler
accsys wrote:
The Toad Charge will solve that problem including proper battery isolation.
For about $110 the toad charger will do the job. OR, you can mount a diode in a plastic box that does the same thing for about $6
Horsedoc
While I am friends with the guy who owns RVupgrades, that seems like a lot to pay for something you can do with a length of wire run battery to battery and a fuse and holder. You are not going to be pulling any major amps like starting the engine, just maintenance voltage.
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
accsys
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
