Converter and Battery Charging Issues
gypsmjim
We have had the 195RB for 2 months now. It is permanently set up on our own private camping property and my only source of power is a Yami inverter generator. Everything has worked flawlessly. However, when I first fired up the generator and checked the voltage I found the battery was not charging. When I wiggled the fuse the fan in the converter started up and it went to 13.5 volts. Since then, same thing. Out of 10 times, 8 times i have to wiggle the fuse to start the charging.
Comments...advice?
2015 Jayco Flight SLX 195RB
Permanently set up on a beautiful mountaintop retreat in Southwest NYS
5 REPLIES 5
Mandalay_Parr
Try a different fuse. Also might have a cold solder joint on the board.
Jerry
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
gypsmjim
That DOES fix it. Until next week when i have to do it again...
Mandalay_Parr
Remove and reinsert the fuse. If that doesn't fix it, look for loose wire or connection.
May have to have an electrical person help you.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
gypsmjim
The main fuse panel has several circuit breakers, plus a row of automotive type fuses. The fuse that I referred to I believe was called the converter fuse, since it was the one that controlled the charging of the 12v battery.
beemerphile1
What fuse?
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
