converting elect to hyd stablizer jacks
kmiller
I been told that my Auto Elect jacks leveling are no longer support with parts. So I need to convert to Hydraulic system. I like to buy a good system since I will be paying to have it installed. Any suggestions I been told Hwh has a good system but after calling the sales department person, he is overwhelmed with this problem and was very rude and short he could not recommend a model for me so I could research? He told me to contact a Rv service and I'm traveling in Oregon.
12 REPLIES 12
kmiller
Thanks Paul,update Guaranty RV service Springfield, Or was scheduled to install hwl system next Tuesday, was told Friday that they are still in Transit and I need to postpone, not sure on delivery date?
azpete
redmond rv service in redmond oregon can help you. hwh designs systems to fit specific chassis designs, so they can help you find the right one.
camping world can also help. even if you dont buy the system from them, they can tell you which system will fit. just ask them for a bid to install a system on your coach. btw, their prices are lower than most dealers.
sorry about the factory experience, i dont work in that office.
i do work for hwh. i do not sell parts or solicit service work on this forum.
paul maddox
MrWizard
Moderator
Moderator
as side note, you don't convert 'leveling jacks'
you replace them with a different operational type/system
I can explain it to you.
1997 F53 Bounder 36s
memtb
You are โ€œnotโ€ the first to experience HWHโ€™s, friendly, helpful, and courteous staff. That alone would send me to Bigfoot!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
MrWizard
Moderator
Moderator
auto electric
you are saying your 30,000# RV ? has jacks with electric motors at each jack ?
the only 'C' have seen that wieghs that much is a Super C on a freightliner chassis
and hydraulic jacks
my 34ft Safari DP was 22,000# and my current 36ft bounder is also 20,000+
please clarify
i haven't seen electric motor jacks on a motorhome of any size , in many years
kmiller
Thanks everyone for your assistance.
kmiller
More Info:I have a 2008 Class C, 30,000. Dry weigh Motor home and the controller will not operate the jacks. I went to a Rv shop and they said they could find a rebuild controller, which was very high price and no guarantee and no refund. I done with my power gear automatic electric Jack leveling system !
buc1980
I will suggest to go with 6 points Lipped if the trailer can be fit.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
1995brave
What are the jacks for? Class "A", Class "C", travel trailer, or 5th wheel?
A little more information might get you some quicker and more accurate answers.
memtb
โ€œIfโ€, you are considering a change of this magatude.....think about going all the way to auto-leveling. The Bigfoot System would get my โ€œhighestโ€ recommendation!
Todd & Marianne
Lwiddis
If you are traveling and the jacks work one way or another, wait until you return home IMO.
Gdetrailer
Sounds extremely expensive to change and very labor intensive..
If the jacks are working (IE no broken gears), can you just run them manually?
If the jacks are good, then you might be able to just bypass the control panel with manual toggle switches and a few relays.
