crutches
richardwise
Looking for opinions or experiences. It's been less than 2 weeks since my right leg was amputated. They gave me under arm crutches in the hospital and I am getting along ok with them, but have been wondering about forearm crutches. Looking at them on the internet, they seem to be easy to walk with and are said to be better for long term users. Anyone have any experience with them? Are they worth trying?
2 REPLIES 2
Old-Biscuit
Due to having my right foot rebuilt 'twice' I spent little over 2 yrs using crutches.
Just a couple of things to consider:
*Both underarm crutches and forearm crutches require upper body strength, though forearm crutches require a bit more from the user.
*It is vitally important that crutches be properly fitted to the user. You should be able to stand up straight comfortably with a crutch.
Elbow crutches are recommended for long-term use. The handgrips need to be level with your wrist bone. Some also have an adjustment for the elbow cuff, which should cradle your forearm just below the elbow joint.
Underarm crutches are usually given for short-term use. To fit, stand up in your shoes and adjust its height so the under arm pad is two finger widths under your armpit. Then adjust the handgrip so itโ€™s level with your wrist bone
Body weight should not be carried by armpit..never damage can occur
*Wearing a pair of cycling gloves helps protect your hands from blisters.
emzee
Richard, they look pretty comfortable compared to the regular ones. I have no idea but I think if you have a medical supply close you could try them. Best to you!!!
