Discolored shower floor
Valkyriebush
Anyone know a product to clean or paint a discolored shower floor? Plastic I assume.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
6 REPLIES 6
westend
What is discoloring the shower pan?
C-L-R or Lime-Away will clean up most rust or hard water staining.
'03 F-250 4x4 CC
donkeydew
stain bulley will do the job.
crasster
Don't know of the discoloration color, but if it is whiter you may have lime. Simple CLR or lime away can remove it. (don't get it on skin)
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Dick_B
You might also try Oxyclean. Make a paste and spread it around, let it sit for an hour then scrub. Maybe try a small space before you wear yourself out scrubbing.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
NYCgrrl
Plastic tiles....hmm how about Krud Kutter. I'd spray the floor and then put paper towels over the floor Oh and be sure to stop the drain.
RAS43
Try Bar Keepers Friend. Worked for me in the RV and at home.
