โSep-29-2013 12:08 PM
โSep-29-2013 11:31 PM
ktmrfs wrote:
Nope, and I have a much better fire pit I carry around. go to an appliance store and beg, borrow or buy a metal washing machine drum. Use a cutoff wheel to cut the center post off if needed. then when you go camping fill the drum with firewood. for fires put the drum on top of the existing firepit grate, or on the ground and toss in some wood and light it. Virtually NO smoke, lots of heat radiated as the metal heats up, almost no clinkers, just some ash in the morning, and almost no soot. All the tiny holes in the drum draw lots of air and give you a hot burning fire. And you will use less wood than a regualar firepit.
If your anal, weld some 3/4" nuts (3) on the bottom and when you don't have a firepit, screw in some 8-12" long 3/4" bolts into the nuts to space it off the ground to draw from underneath.
Based on comments from other campers when they see mine, I'm tempted to carry a "spare" or two and have them for sale at a campground.
โSep-29-2013 07:14 PM
โSep-29-2013 06:58 PM
โSep-29-2013 03:59 PM
โSep-29-2013 03:43 PM
โSep-29-2013 01:53 PM
mhardin wrote:korbe wrote:
I would not want to carry a grate around just for this purpose. We have found that with the right placement of the wood, it burns just fine.
Agree!
โSep-29-2013 01:11 PM
โSep-29-2013 01:06 PM
โSep-29-2013 12:41 PM
โSep-29-2013 12:30 PM
'15 Chevy Silverado 2500 HD
'18 Forest River Avenger :C "Dolci"
Kipor KGE3500Ti
CHECK OUT THE RV.NET BLOGS!!
โSep-29-2013 12:20 PM
