Fireplace heater beeping
roaminaround
We have a new Rockwood with a Titan electric fireplace heater. Every time you hit a button on the unit or the remote it beeps loudly. I've read online about disabling or removing the piezo speaker and wondering if anyone has done this. I assume this would void my warranty but I really don't care. It's driving the dog crazy.
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel
2006 Fish Rite 18' Yamaha 115 and T8
6 REPLIES 6
StirCrazy
Moderator
Moderator
mine has a button to turn the beeps off.....
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Dtank
roaminaround wrote:
So I disassembled the unit and found the piezo. I carefully drilled out the back of it till the back came off. I saw a foil diaghram and removed it. Beeping is 100% gone. Reassembled and tested. Success
Now you just need some wood for the fireplace - and turn the AC "up"..:W
roaminaround
wa8yxm
I have taped over pizo deices to mute them but usually.. They come in two types.
PC Mount.. now disabling those has to be done very carefully. Basically unsolder and remove
Wire lead type Often if you trace the wire back to the PC board there is a plug. Simply unplug.> NOTE you an get a "less noisy" one and plug in
Option 2 is cut a wire and tape the ends both off. and together but not touching
Do it so it is clear what has been done.
ppine
An example of options that are more trouble than they are worth.
Fizz
Try stuffing a cotton ball in it to muffle the sound.
