โAug-05-2018 02:47 PM
โAug-19-2018 08:10 AM
โAug-16-2018 07:25 AM
chrispitude wrote:4x4ord wrote:
I don't understand the value of a front receiver though..... why not just back your trailer in to where it goes?
I have a narrow 300ft driveway, 90 degrees off a public road. Sometimes neighbors park across the street. Truck plus trailer is about 46'. It would be much easier with the steering wheels right at the pivot point, as I can adjust the trailer's angle with much less tow vehicle input.
โAug-11-2018 07:09 AM
โAug-10-2018 05:44 PM
โAug-10-2018 09:17 AM
mowermech wrote:
IMO, all manufacturers build a safety factor into their ratings.
Nobody knows what that safety margin is, and they more often than not won't tell anybody.
Yes, the receiver will handle more than it is rated to handle. The "Breaking Strength" is not advertised, as it is on rope, cable, and chain.
If it were me, I would go ahead and use the front hitch to slowly move the trailer. If the hitch broke, I wouldn't even bother to tell the manufacturer. Exceeding the ratings voids any warranty, it would make no sense to bother Customer Service with it!
โAug-10-2018 09:00 AM
โAug-10-2018 07:30 AM
โAug-07-2018 01:50 PM
โAug-07-2018 11:35 AM
BarneyS wrote:
How do you plan to see around the front of the trailer while you travel along that 300ft driveway? Can't wiggle back and forth and see where your are going like you can with the tongue on the rear of the truck. I can see making it easier to back in from the street however.
Personally, I would just use my mirrors and back in all the way like normal.
Barney
โAug-07-2018 10:42 AM
โAug-07-2018 03:00 AM
โAug-07-2018 02:40 AM
โAug-06-2018 04:39 PM
boogie_4wheel wrote:
05 3/4t Dodge with Curt (if I remember correctly). I've pulled the sticker and repainted it over the years. 90% sure it's a Curt.
demiles wrote:
I used a front hitch to set my trailer in a tight spot in my yard. Tongue weight was in the 700-750 range, the truck was a 2500 Silverado EC LB. It really depends on how well the front suspension can handle the weight.
โAug-06-2018 01:27 PM
