Generator not powering house-already checked breakers/fuses
jimdmorrison
Finally got generator running recently. Worked with vacuum and a/c last week, but yesterday generator runs but no power to the house. Checked breakers in Rv and on generator. Checked fuses. Itโ€™s the set up where the cord that plugs into the shore plugs into an outlet that I assume runs straight to the generator.
Any thoughts? Thanks!
7 REPLIES 7
Dutch_12078
pianotuna wrote:
make and model of generator would be good.
The OP has an Onan QG 4000...
Dutch
2001 GBM Landau 34' Class A
Bobbo
You need to start at the source and check to see where power stops.
1. use tester to see if you have power on generator outlet. If yes, go to step 2.
2. use tester to see if you have power to back of main breaker. If yes, go to step 3.
3. use tester to see of you have power to front of main breaker.
and so on and so on.
When you FIRST have no power where you should have power, you have found the problem. It is between where there is power and where there is no power. You have narrowed it down.
Report back where is the last place you have power and the first place you don't have power and we can help guide you from there.
Bobbo and Lin
pianotuna
Nomad II
Nomad II
Regards, Don
wa8yxm
There are two different definitions of EMS, Intelletec nd Progressive Industries
The PI unit will sometimes not pass Generator power
Likewise your Automatic Transfer Switch, may be fried (if you have one)
Or your manual transfer Device (the plug) came out of the socket.
ktmrfs
do you by chance have an ems? if so does the generator have an unbonded ground? (likely) if so the ems may not let power to the trailer since it detects an open ground.
2011 Keystone Outback 295RE
enblethen
Start genset, check the receptacle for 120 volts AC using meter or test lamp leads into the blades.
No power means genset power is not getting there. check wiring connections at genset junction box.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rk911
are you getting power to the 120-vVAC outlets when plugged into shore power?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
