generator
jiri
what is the best generator to buy if I need to run 13 500 A/C?
25 REPLIES 25
C_B_
Dakota98 wrote:
I'm a fan of Champion generators in consideration of performance, cost & customer service. Although the Honda & Yamaha are the most popular, I believe Champion deserves it's place with the big two.
I agree with others that have mentioned the weight factor. Two, 2000 watt Champion units may be best, at only 57 lbs each. They are rated at 53db at a distance of 23'
Two NEW 2000 watt bundle package. + FREE shipping @ $1239
Two "Refurbs" 2000 watt bundle package.
+ FREE shipping @ $899
I don't know where you got the 53db at a distance of 23' from.
On Champion Power Equipments web site their Model #73534i 2000W inverter generator has a db rating of 68db at 23 feet and a dry weight of 48.5 lbs
Compare this to the Honda 2000's
59db at rated load at 9 feet and a dry weight of 46.3 lbs.
Noise and weight wise Honda is surely better.
Looks like the Champion will run longer on a gallon of gas probably due to the fact it has a 80cc engine verses the Honda 98.5cc.
Price wise Champion wins hands down.
Which would you want in the campsite next to you?????
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
edbehnke
regardless of what you buy, remember that noise is a BIG issue if near people. i've ran my 13.5A/C with my 2000 watt honda and it is very very loud and running at its max.
eddie and sandie
3402 Montana 2013
Ford F350 2015
pianotuna
Nomad III
Nomad III
Hi,
I would want a generator to have electric start. So far as I am aware none of the 2k units offer that as an OEM solution.
I solved the weight problem by putting the genny on a rack at the back and having a ramp.
It is cheaper to go to an inexpensive campground than to run a generator 24/7 for air conditioning.
On the whole, I wish I had purchased more solar and not bothered with a generator at all (including running the roof air from solar).
Regards, Don
Dakota98
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
smkettner wrote:
3000 is heavy. If heavy is an issue consider 2x 2000 in parallel.
Red or blue is your choice.
But honestly if I need air 24/7 I am looking for hookups.
X2 on this ^ ^
I use x Honda EU2000's ..each one by itself is light enough to carry around alone
I did see some nice yellow champion 2000's . they now offer the ability to stack and run parallel and a lower cost than the red's or blue's... just not sure how quiet they are ??
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
horton333
I have a no name 2.2 kw generator that runs this size AC with never a problem. The Hondas are much quieter, but numerous times more expensive.
Ford Explorer or Chrysler 300C to tow with.
Tracer Air 238 to be towed.
Triumph Thunderbird Sport - with the toy-hauler gone it's at home.
Retired very early and loving it.
time2roll
pianotuna
Nomad III
Nomad III
Hi jiri,
Welcome to the forums.
In no particular order:
Yamaha 3000 iSEB, Honda 3000, Yamaha 3000 iSE, Champion 3100.
Regards, Don
azrving
I use a 3000 Honda with remote start. It's bolted into the truck bed and has a ventilated metal enclosure. It works good and is still pretty efficient when on eco mode and running my converter or battery charger.
As others said, the 3000 is heavy and I consider it a bolt in model. I would never consider moving it around. If you want to pack them away when you are done go with 2000's. One 2000 can be used if you want to charge or run smaller 120 v loads.
edbehnke
you will need at least 3000+ watts....pick whatever one you can afford.
yahama and honda are great and quiet.
eddie and sandie
3402 Montana 2013
Ford F350 2015
TucsonJim
I have a 3000Watt Honda which will run that AC just fine. If I had to do it over again, I'd get two 2000 watt generators and run them in parallel. The 3000 is too heavy to lift by myself.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
