โJan-22-2013 05:07 PM
โMar-12-2013 06:40 PM
โMar-12-2013 06:19 PM
โMar-12-2013 05:01 PM
BenK wrote:
Just in to peek and not enough time to really noodle this, but am liking it more.
So much more, maybe this instead of a Pullrite...just a maybe till more time
to go through how it works. The Pullrite's loss of ground clearance
a potential deal breaker for me...especially in light of my new found
attributes of this Ox system
โMar-12-2013 11:28 AM
โMar-09-2013 11:17 AM
BenK wrote:
...snip...
Do see a new potential down side and is with extreme angles while
parking/maneuvering/etc. That limited number of chain links not
captured, which is a good thing while towing, becomes a potential
limiting factor...will the bars bend even more? Will the 'U' bolt
allow the chain to move more? Will the chain attachment allow the
chain to unwrap in the 'right' direction, therefore allow more movement
while turning 'tight'? This is the good and bad...it is part of
how they control sway while traveling, but that becomes an issue
while parking...I think...for now...anyone have one of these?
.....snip
โMar-09-2013 10:00 AM
โMar-08-2013 07:11 AM
โMar-08-2013 06:52 AM
โMar-08-2013 04:08 AM
โMar-07-2013 05:29 PM
Francesca Knowles wrote:Much of the world outside of North America uses a variety of towing "stabilizers".
Of course, with properly sized/inflated tires, the correct load distribution, and the correct speed one doesn't need mechanical sway controls at all!
As is well known throughout most of the trailering world EXCEPT in North America...
โMar-07-2013 05:03 PM
gmw photos wrote:BarneyS wrote:
I fail to see how the chains can supply much,if any, sway control at all since the brackets pivot right along with the a frame and bars in a sway event and in a turn. The bars DO move forward and back but are not rigid side to side, which would be necessary for sway control to take place.
Barney
When the trailer is not in line with the tow vehicle, the bars have an unequal force applied to them. That unequal force is applied ( if I am understanding it correctly ) because of the fact the head of the hitch is tilted backwards at it's top.
As proof of this, when I am cranking up the chains on this hitch, if I don't have the truck exactly straight in line with the trailer, one bar will "chain up easily" while the other bar is very difficult to get the latch to turn. In that case, I have to crank up the tongue jack some more to get enough weight "off the bars".
It's that unequal force, created by the geometry of the hitch head, bars, and attaching chains that is apparently the force the keeps the trailer inline when it tries to sway.
At least that's my take on it. All I know is it works. And the weight distributing part works as well, a fact I verified by setting mine up and going to the CAT scale.
โMar-07-2013 04:22 PM
โMar-07-2013 03:58 PM
Barney
โMar-07-2013 03:23 PM
A w/d hitch with chains doesn't have sway control- for that you need one like the Equalizer or Blue Ox, which has rigid bars where the chains would be.
โMar-07-2013 01:13 PM
