Jun-06-2017 06:33 PM
Jul-03-2017 08:03 PM
Jul-03-2017 07:27 PM
Jul-03-2017 07:06 PM
Jul-03-2017 03:11 PM
Jul-03-2017 12:31 PM
familyman5 wrote:
Good question Blownstang01, I guess because the manual says the key should be in the accessory position. I wonder why they would say that if it was not necessary.
Knowing that the manual said this the guy who wired the explorer to the motorhome did so in a way that the key has to be in the accessory position for the brake lights and turn signals on the explorer to work.
Jul-02-2017 07:29 PM
Jul-02-2017 07:18 PM
Jun-23-2017 04:52 AM
Jun-19-2017 05:14 PM
CA Traveler wrote:wilanddij wrote:X2 You can use a separate cable or upgrade to one with more wires.
Do yourself a favor and install a charge line from the MH to the battery. When I bought a 2014 C-Max I checked a couple of forums on the subject, and adding a charge line seemed to be the most popular solution. Adding a 10A line to my umbilical wasn't very difficult. Put a fuse or breaker on each end to protect everything. Never have had a problem with running the battery down when towing.
Mine has 3x wires for the lights, 2x heaver wires for ground and battery charge and one that provides a connection from the stop lights to a dash light so that I know when the toad brakes are applied.
BTW Before the charge line my CRV never had a dead battery but I knew there was some battery drain and added the charge line.
After one day of travel I left the CRV key on. Dead battery the next morning so I shifted to Park and then it was locked in Park, would not start and attached to the MH. My jumper cables would not reach. That was fun. :R
Jun-19-2017 06:44 AM
Jun-19-2017 06:19 AM
Jun-18-2017 02:07 PM
Jun-13-2017 09:04 AM
johnwalkerpa1 wrote:
Only one additional note...
I'm reasonably sure that the Ford recommendation to start the engine after 5 or 6 hours of towing has nothing to do with the electrical system or battery. As mentioned earlier, 5 minutes of idling would do almost nothing to recharge the battery....I believe its for lubrication... of course I've been wrong before 🙂
Jun-13-2017 07:45 AM
