โFeb-12-2016 07:42 PM
โFeb-14-2016 10:22 AM
ktmrfs wrote:
Rather than talk about what is or is not tongue weight, I think about it more of what weight do I want the WD hitch to distribute. Like Larry, My truck bed is usually pretty full.
even w/o the trailer hooked up, the front of the truck rises some, not much but some.
I've set my WD hitch up so that with my typical truck bed load AND the trailer hooked up, once the bars are engaged, the front of the truck is back to the level it is if there is NOTHING in the truck bed and NO trailer hooked up.
So, like Larry, my WD hitch is transferring this extra weight, in this case tongue weight and stuff behind the truck axle, back to the TV front axle and Trailer rear axle.
โFeb-14-2016 10:15 AM
โFeb-14-2016 09:28 AM
lbrjet wrote:
With your theory Larry my truck's bumper, receiver, tail gate, spare tire and everything else aft of the rear tires would be considered tongue weight.
When you set up a WDH you are supposed to load the truck as you would for camping first. This is the baseline for all further calculations and none of this weight is tongue weight.
We can just agree to disagree.
โFeb-14-2016 07:12 AM
โFeb-13-2016 08:07 PM
Terryallan wrote:LarryJM wrote:Terryallan wrote:lbrjet wrote:
Weight in the back of your truck counts against payload, but it is not tongue weight.
This is the correct answer. The load in the back of the truck, including the hitch itself is NOT tongue weight. It is part of the payload / GVWR of the truck.
Tongue weight. Is the actual weight of the trailer tongue. Determined mostly by where you load the weight INSIDE the trailer.
Thing is. You have to leave enough payload to carry the tongue weight, because it too counts against the payload / GVWR of the truck. You also have to be sure your receiver is rated to carry the tongue weight of your trailer. Say your receiver can carry 950lb of tongue weight using a WDH. Your tongue weight cannot be more than 950lb.
And do remember. the truck's brakes are only designed to stop the GVWR of the truck. They are NOT designed to stop the GCVWR which is the truck, plus the trailer. In other words, They are not designed stop the GCVWR of the truck.
That view is IMO too simplistic and not really correct. My answer to this is in my post HERE. Ron in his last post agrees at least in concept with parts of my position. I do agree with his view as it applies to what to use as the percentage of TW to total trailer wt. to estimate overall trailer stability.
I do concede that my position regarding cargo aft of the TV rear axle is fairly complex and near impossible to accurately determine since what is important for receiver TW rating and sizing of WDH bars is the "weight" that would be applied at the point of the ball that would equal the same "lever moment" as this "additional" cargo wt. I would think somewhere this would be in the range of 25-75% of the actual cargo wt. added.
Larry
Simplistic or not. It is factual. Tongue weight. It ONLY the weight of the trailer tongue. Weigh the tongue alone to get it. When hooked to the truck. the tongue weight takes up part of the payload / GVWR. Pretty much it.
To say that the cargo in the back of the truck is part of the tongue weight is not realistic. After all, Unhook the trailer and that cargo weight is still there, but the tongue weight is completely gone. what would you call it then? No tongue, no tongue weight.
โFeb-13-2016 04:54 PM
Larry
โFeb-13-2016 02:29 PM
Weight in the back of your truck counts against payload, but it is not tongue weight. I know some hitch companies suggest weight behind the rear axle should be considered as TW when sizing your WDH. I think that is beans as there is no need to distribute any of that weight. This thinking is a recent phenomena and I have no idea how they came up with it, other than to maybe sell you a larger hitch for more money. A 900 lb dry TW will turn into 1100 lbs so you are on the edge but still within spec. OK? It's up to you.
โFeb-13-2016 11:43 AM
โFeb-13-2016 10:09 AM
rhetthughes wrote:
Thank you all for the helpful advice. Sounds like I should work towards finding a camper that meets our needs with a tongue weight down in the 700 lb range to be safe.
โFeb-13-2016 08:01 AM
โFeb-13-2016 07:24 AM
โFeb-13-2016 07:21 AM
harley-dave wrote:
You guys are not entirely correct. Tongue weight is just that. how much weight the tongue is putting on the hitch ball. Here. There are several sites around discussing this. Don't get this one confused with PIN weight which applies to 5th wheels which will include all that other weight in the back of the truck.
Dave
โFeb-13-2016 04:23 AM
โFeb-13-2016 03:43 AM
โFeb-12-2016 08:47 PM
