Honda EU3000is
Jguyotte
Anyone know if the Honda EU3000is generator charges its own battery while running.
11 REPLIES 11
Sam_Spade
bobsallyh wrote:
Sam Spade, this isn't answering to Honda, but our stupid Onan Marquis Gold 7000 DOES NOT charge start battery.
Well then it is broken because it certainly should.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
bobsallyh
Sam_Spade
Jguyotte wrote:
I didn't realize the battery did not come connected. I found it and it starts fine.
AND it probably came with an instruction sheet too. :B
Jguyotte
Dtank
pa traveler wrote:
Will be buying one soon,not sure where to get best price. Wanted a remote start but not for $350 dollars.
The best place for "Everything Generator" is the *Tech Issues* forum..;)
pa_traveler
wanderingbob
My Honda 3000is has been in use for 8 years and I do not even know where the battery is , you just turn the key and it starts . Probably the most dependable piece of equipment that I have ever owned .
pianotuna
Nomad III
Nomad III
My Yamaha 3000 Sieb does charge the starter battery.
Regards, Don
Sam_Spade
This is a question I would not think of asking. It would be pretty silly if it did NOT do that. Pretty much ALL engines with an electric start should charge their own battery while running.
As for battery longevity, if AGM is available in that size it should last twice as long or more because it tolerates neglect better.
RoyB
It would be easy to find out using a multimeter.
The internal Honda Start Battery should read around 12.6-7VDC when fully charged and the Honda is not running...
Then start the Honda and measure the battery terminals again while the Honda is running. You should see a jump in DC Voltages up to around 13.6VDC or higher across the battery terminals when the Honda is running.
Lawn Mower motor chargers with start batteries do not last long as a general rule. I have to replace mine about every two years. I suspect the reason is the DC Charging voltage is not regulated and does not follow the required DC Charging voltages to properly charge the battery.
Intermittent charging of the batteries not obtaining the 90%-100% charge state will eventually ruin the battery...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Xflyhighx
Yes
2019 Cedar Creek Champagne 38EL
TrailAir Pin Box
Hensley TS3 trailer saver
2017 Laramie Longhorn 4x4 dually
14' Porta-bote
Honda 3000is or 2 Honda 2000โ€™s
Life is good in the good old USA
