โJun-06-2018 04:26 AM
โJun-07-2018 06:40 PM
routeforty wrote:mkirsch wrote:Amen to that. I noticed our pontoon trailer tires wearing on the inside, then looked at the axle, which was bowed so badly it looked like it was smiling at me. Took it to a scale and the gross weight was 2950lbs on a 2500lb axle. Had it changed to a 3500lb axle and end of problem. This was a brand new boat & trailer with only 2 trips from Oh to Fl, and about 10 trips to the lake. Maybe 4000 miles(but probably less).Gary
Yeah, probably overloaded. Often times you'll roll up on someone towing a boat on those spindly little 12" tires, and you can see they're clearly overtaxing the tires and axle, as the wheels are splayed out at a 15 degree angle to vertical.
What size tires? What is the weight rating? What boat?
โJun-07-2018 05:47 AM
โJun-07-2018 05:32 AM
valhalla360 wrote:
Were they fully inflated? Underinflated tires can overheat.
โJun-07-2018 05:26 AM
โJun-07-2018 04:29 AM
SweetLou wrote:
Tire set up is how this has been rolling down the road since 2006. Single axle, not overloaded because it is designed for that boat. Nothing else was in the boat. [COLOR=]I inflated the tires to 30 lbs and they have always been jacked up off the ground for winter storage. I agree that I was close to tire failure but I just couldn't understand why they got so hot when the conditions were ideal and the load was normal.
โJun-07-2018 03:05 AM
SweetLou wrote:
Tire set up is how this has been rolling down the road since 2006. Single axle, not overloaded because it is designed for that boat. Nothing else was in the boat. I inflated the tires to 30 lbs and they have always been jacked up off the ground for winter storage. I agree that I was close to tire failure but I just couldn't understand why they got so hot when the conditions were ideal and the load was normal.
โJun-07-2018 02:50 AM
โJun-07-2018 02:45 AM
nickthehunter wrote:
What was the temperature of the pavement the tires were running on?
โJun-06-2018 10:54 AM
โJun-06-2018 06:53 AM
โJun-06-2018 05:39 AM
โJun-06-2018 05:24 AM
โJun-06-2018 05:12 AM
โJun-06-2018 04:55 AM
โJun-06-2018 04:36 AM
