โJun-15-2013 08:09 AM
โJun-17-2013 05:32 PM
โJun-17-2013 01:45 PM
โJun-17-2013 12:22 PM
โJun-17-2013 10:58 AM
tgoodhew wrote:
Thanks everyone - I guess I don't know if the dealer will actually use scales or not - Given that they're a fair distance from where we live I would assume that even if they did they wouldn't be asking me to come back in once we're loaded for adjustment.
โJun-17-2013 07:40 AM
I don't recall using the word "thousands" or "1000's" in any post. You seem to have me confused with someone else. Might want to use the quote thing rather than putting words in people's mouths. Unsanitary at best.
โJun-17-2013 05:29 AM
โJun-16-2013 09:36 PM
I looked at a lot of setups this weekend while camping up on Lake Michigan. If you saw some of them you would not worry too much about yours. The "experts" on here may preach for a perfection, where every pound must be accounted for, but that is not always real world. I am not saying that a bad setup is okay, but that an okay setup is most common.
โJun-16-2013 06:49 PM
โJun-16-2013 11:43 AM
โJun-16-2013 10:48 AM
Maybe I'm just worrying too much about getting it from the dealer to my house to the scales - It's not going to be that long a distance, probably 40 miles all up.
โJun-16-2013 10:22 AM
โJun-15-2013 05:52 PM
Ron Gratz wrote:
IMO, GM specifies on the basis of height because they assume the number of people who might measure heights will be significantly greater than the number who would measure weights.
The philosophy could be that it's better to get approximate axle loads via height than to get nothing at all.
I'm guessing that GM's dual specification of 50% elimination of front-end rise in some cases and 100% elimination in others is related to the SAE J2807 Standard which specifies trailering stability at both 50% FALR and 100% FALR.
The SAE specs are based on front axle load and not on steering geometry.
Ron
โJun-15-2013 04:32 PM
Think of the 1,000s of hitches installed at dealers; do they run the rig down to the scales?
โJun-15-2013 04:28 PM
skipnchar wrote:I wouldn't count on that.
---What you're replacing is half the RISE not necessarily half the weight (but you'll find that they are actually very close to one and the same.
