How to tow a small sailboat and an RV on a pickup truck
rv_sailor_man
So I have a Ford F-150, I am in the market for an RV right now and have not decided on Fifth wheel or Travel trailer. Either way I am looking at ball park 27'. Now I want to bring a small sailboat with me, its a JY15. The specs on the sailboat are as follows:
15' long
5' 10" wide
3' tall
Weight of the hull is 275 lbs and the sails and mast and stuff can be stored in the truck and/or rv.
Is it possible to get this around with me? Suggest 5th wheel or TT or what?
They make trailers for these boats but I am thinking there might be a way to put it in the truck bed and have a TT.
8 REPLIES 8
stevepk
Also you need to know the laws for the states you'll be visiting. Here in Ill-a-noyed it's illegal to double tow.
2018 F-250
2017 Prime Time Avenger ATI 27RKS
Bedlam
Moderator
Moderator
It's possible to do what you want with more truck or you need scale back the size of the travel trailer you wish to tow.
blt2ski
Moderator
Moderator
First off, whatbyoubwant to do is VERY possible. Issue I see is potential lack of payload or power in 15 series truck. Even a 25 might have issues.........but, I personally see how this can be done.
As noted, a toy hauler with.enough garage space. A pickup with a rack correctly located. Or a boat trailer behind a 5w will also work depending upon the jurisdictions you travel thru.
All numbers need to be wieghed along with the power requires to do the task you need to do.
As I noted, very poster to do frankly. Not sure a 15 will do it depending upon model etc.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
rv_sailor_man
midnightsadie wrote:
seen a truck today with a boat on a ladder rack. the ladder rack run clear to the front of the trucks hood .
Awesome! So far this seems like the best solution although a pain to get up there but doable for sure.
midnightsadie
IAMICHABOD
You might try a Toy Hauler.
Here Is A Thread that shows what other folks have done.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Naio
rv_sailor_man wrote:
So I have a Ford F-150, I am in the market for an RV right now and have not decided on Fifth wheel or Travel trailer. Either way I am looking at ball park 27".
With a 27-inch RV, I think you will be fine. Just put it in the truck bed and tow the boat. (Shades of Spinal Tap.)
If you want a bigger RV, though, I suspect you will run into your truck's towing and/or weight limits. What are those? Can you get them off the door sticker?
Edit: I had a Barbie class A when I was a girl... I think it was about 27 inches.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
rv_sailor_man
Also open to a sunfish instead of the JY15 but not preferred. The specs on that are as follows:
13' 9" length
4' 1" wide
120 lbs
So substantially smaller.
