Issue with supplimental braking system
navydavy
I tow a 2011 Honda 2011 CR-V and use a Blue Ox Patriot Brake System. This system has to be pulled into the lighter outlet at least to setup I assume it requires power to function. The ignition key must be turned one position to keep the steering wheel from locking up while towing the Honda. The problem is that it drains my car battery to the point that it has to be recharged or jump started in order to disconnect it from the RV. Has anyone else seen this or know how to eliminate it.
4 REPLIES 4
EsoxLucius
I just had a charge line installed.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
aslakson
There are also instructions in the user manual on which fuse you need to pull or switch out to remove power from the entertainment system. That's a major power drain when the switch is on, and by pulling it (or better, using a cutout switch) you'll solve your problem.
al
Fulltiming since Apr 2007 in 2000 Rexhall Aerbus, towing 2012 Honda CRV. 47 of the lower 48 so far.
sch911
In these situations you need to run a charge line from the MH to the towed vehicle to keep the battery charged while driving. It's really very common....
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Mandalay_Parr
How often do you start the engine and cycle the transmission?
There is a fuse you can pull for the radio and nav system.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
