LT Tire Replacements - All season
JBarca
Nomad II
Nomad II
Time for new tires. Trying to find someone in the same weight range or that has been running their chosen brands close in the weight range listed below.
Currently using. BFG Commercial TA's LT225/75R16 LR E. 2,680# @ 80 psi. Now 5 1/2 years old.
Axles: 5,000# springs are the limiting factor.
Trailer GVWR: 10,000# Camper loaded: 9,920# GVW
Largest loaded axle: 4,400# aligned with 5,360# of tires/axle
Needs: I need/want to be able to run winter (below freezing) and summer temperatures on the same tires.
I have had 2 failures this year. This might be from 2 reasons:
1. It is not beyond impossible I ran into a patch potholes. The tires could have been damaged internally and manifested itself to the recent failures.
2. These current failed tires were also potentially made in the same BFG plant they had the recall on the next size from mine during 2012 when I put mine on. This may or may not have to do with the recent failures. BFG Recall
Mine look like this video. Tire shop showing recalled tires
I have a TPM system (Truck Systems TST) and the running pressures at 60 mph were 90psi and 89F stem temperatures when the failures occurred.
I'm not blaming the tires at this point, I want the best LT option within reason to replace them with.
New replacement choices I have found.
Michelin XPS Ribs: They are only a summer tire
Bridgestone Duravis R250: They are only a summer tire.
The above both have been reported to give excellent service however I need all season.
Bridgestone Duravis R238: Duravis R238 These appear to be an option as they are all season and similar tread as the R250's
Firestone Transforce HT: These appear to be an option, maybe not as heavy duty as the Duravis R238's Transforce HT
BFG Commercial TA 2: An upgraded version with "Cool Wedge shoulder insert" from what I already have. BFG Commercial TA 2's
BFG has had now 2 recalls in the Commercial TA's including the new 2 version. I linked 2012 one above and here is the 2015 recall. https://www.bfgoodrichtires.com/safety-recall.page
With that, I'm not real high on another set of BFG Commercial TA's.
Anyone with the same size, running all season tires? and other brands in the same or slightly higher weight range? Again need all season options.
I already went through the ST to LT upgrade. See here for wheel weights etc. ST225/75R15 to LT225/75R16 Conversion
Thanks
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
22 REPLIES 22
Grit_dog
Navigator
Navigator
Treads blew off. OP showed it.
To the OP, theyโ€™re trailer tires, get some, put them on the trailer, drive away.
Regarding winter traction, those that said a trailer doesnโ€™t need traction because it doesnโ€™t have a drive axle, LOL..........
Agree, I haul a trailer around typically in the worst weather possible, on purpose. Regular tires. If it had studs, snows, chains, etc I could go faster in some situations.
For a bestof both worlds, get whatever highway tread tires you want and then have them siped. Instant snow tires that work in the summer. May lose a little tread life, but traielr tires generally donโ€™t go tread bare before they age out or die anyway.
time2roll
Goodyear All-Terrain Adventure with Kevlar is available in LT225/75R16
Great all season tread. Excellent tire.
JIMNLIN
I've used a couple of sets of Cooper SRM II in LT235/85-16 E on my equipment trailers. Cooper dropped them but now recommend the Cooper Discoverer HT3 for trailer use.
And don't forget Goodyears Wrangler HT which they recommend for trailer use. These tires came OEM on some trailer brands in the late '90s and early '00s.
I've used several sets of LT235/85-16 E in the older BFG Commercial T/A which were a very good tire for 10-15 years for BFG. Great service like 50k-55k miles and seven years and no issues.
It would be interesting as to know why the Commercial T/A tires suddenly started shedding their treads on trucks/trailer/suvs/vans.
Turtle_n_Peeps
When you say you have had 2 tire failures; what does that mean? Did they bubble? Did they blow the tread off? Did you pull over and find a disk on your rim?
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
BurbMan
Hi John, I will agree with previous posters, winter/summer tire designations apply in the context of traction. Softer rubber gives you better grip as it conforms to the road surface better, so "winter" tires are formulated to stay pliable in colder weather. The corollary to traction is wear, so "summer" tires that are run in high heat are formulated to stay stiffer so they don't get too soft and wear out too fast.
That said, your trailer has no drive wheels, so traction is of no concern. When I upgraded to LTs on the Terry, I went to the local tire chain and said, "What's the most economical tire you have?" Now I am on my 5th season of Commodore LTs, and they look as fresh as the day the left China on the boat.....
On the Suburban I am on my 3rd set of Bridgestone Dueller Revo II's, and when these are done a 4th set will be purchased...
BarneyS
Good morning John:
I have two comments.
First, although not on my trailer I have been running the Firestone Transforce HT on my Ram for the past two years. A trip to Florida and another to Texas under their belts (pun intended :))and they seem to handle and wear very well.
Second, I kind of agree with the two posters above regarding the need for all season tires vs regular summer tires. That engineer mind of yours is working overtime again (think drag coefficients and Leonardo :W ).
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
MFL
Nomad II
Nomad II
eHoefler wrote:
An All Season tire is not necessary for a trailer. I have pulled our heavy fifth wheel with rib tires in the snow and ice with out issue. I have Roadmaster RM170 made by Cooper Tire on our rig
I agree...John, IMO, you are over thinking this summer/winter tire thing. I have towed my 7-23 26' actual length enclosed snowmobile trailer on glare ice, passing the truckers going 35 mph in Montana, Idaho, and Wyoming, using truck 4WD. I sometimes towed on roads with deep snow, up to 1', with GY Marathons, without issue. Trailer towed great, but for trailer brakes, there were times, downhill in mountains, that chains on one axle would have been nice.
I would just go with one of the proven Summer tires you mentioned.
Jerry
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
