โAug-30-2021 03:26 PM
โSep-03-2021 09:01 PM
โSep-03-2021 06:22 PM
โSep-03-2021 07:38 AM
2112 wrote:
Did you try these adjustments and take measurements again? I find it hard to believe your front struts are bad after only 37000 miles in 4 years. I'm still on my original fronts after 135,000 miles and almost 11 years. I replaced my rears about 2 years ago.
โSep-03-2021 07:29 AM
wing_zealot wrote:
That truck is perfectly capable of hauling that trailer unless you are carrying a cord of firewood in that back while you go camping. First off you need to determine what your tongue weight % is. Start weighing things, ideally, the 3 trips across the scales method of determining weights would be best. learn about weights and ratings here Clicky
โSep-03-2021 07:21 AM
โSep-03-2021 07:07 AM
bobby7718 wrote:Did you try these adjustments and take measurements again? I find it hard to believe your front struts are bad after only 37000 miles in 4 years. I'm still on my original fronts after 135,000 miles and almost 11 years. I replaced my rears about 2 years ago.
Heard back from the manufacturer of the WDH, the impression he got is the rare axles seem squat too much(not lifted up due to insufficient weight distributed).
Here are his suggestions.
- The hitch ball needs 7 degree towards the trailer
- Hanger needs to be 1 hole up
- The hanger's direction needs a bit adjustment(to allow the spring bar resting on both end of the hanger)
Will give it a try soon.
โSep-03-2021 06:24 AM
โSep-03-2021 05:22 AM
bobby7718 wrote:
an update on this topic - turns out the truck has a bad pair of front struts assembly ! Scheduled an appointment with the dealership, will report back after the truck been fixed.
โSep-02-2021 10:01 PM
โSep-02-2021 08:45 PM
โSep-02-2021 07:57 PM
โSep-02-2021 01:26 PM
โSep-01-2021 06:34 PM
โSep-01-2021 06:28 PM
2112 wrote:
It looks like you have the 600Lb kit. The trunnion bars may be maxed out.
A trip to the CAT Scale loaded ready to camp is in order
โSep-01-2021 08:41 AM
bobby7718 wrote:
3000 lbs max-payload could well be the dealership was lying to me.
An interesting story - When I visited CampingWorld, the service department couldn't find any towing capacity for my vehicle(via the towing chart). Then she called dealership(who sold me the TV), and confirmed that the max payload and towing capacity. Those numbers(agreed increditably high) are different than what the yellow stick says(which is 1814 lbs). The manager, who said she has been working in the industry for 25 years, said "The yellow stick could be off if there are some customization package installed to the TV", and for a fact, I knew from the windowsticker the previous owner had bought it with the towing package(not sure whether it's the max-tow-package though).
With that being said, I still wouldn't trust those numbers, wouldn't put crazy load on it, but thinking loaded TT 7000 lbs shouldn't be too much for it.
The current tire does have 50 PSI rated. See the attachment below.
