โJan-13-2014 09:05 PM
โJan-16-2014 07:45 PM
tenbear wrote:CavemanCharlie wrote:
When I look this up on Amazon it seems there are several different kinds. What kind are most of you using in your RV?
Here is a link. I have an older version of this one. I use the old existing holder and I replaced the valve with one that is continuously variable and completely shuts off.
โJan-16-2014 04:09 PM
โJan-16-2014 09:27 AM
dgcarver wrote:
Maybe the trickle flow allows the hot water to stay hot? On my factory supplied one, when I shut off the flow for a few minutes to soap down, the water is cold for a few seconds when starting to rinse. It that the same with the Oxygenics when you use a complete shut off?
โJan-16-2014 08:10 AM
โJan-16-2014 07:23 AM
nohurry wrote:Ron3rd wrote:
They also have a new model with built in shutoff.
It's not actually a shut-off. The description says it "Allows you to pause the flow to a trickle". I have this on our short list to get, but I'll probably install a shut off from the hardware store.
โJan-16-2014 06:33 AM
โJan-16-2014 05:08 AM
โJan-16-2014 04:49 AM
path1 wrote:
How are those oxygenics shower heads working out for everybody? If you have one are you pleased with it?
โJan-16-2014 04:44 AM
โJan-15-2014 05:04 PM
โJan-15-2014 01:32 PM
โJan-15-2014 11:05 AM
โJan-15-2014 10:53 AM
โJan-15-2014 08:31 AM
โJan-14-2014 01:31 PM
