Power cord
Skipg
Is there any problem leaving the power cord on my TT plugged in when when not in use.
10 REPLIES 10
Grit_dog
Navigator
Navigator
wa8yxm wrote:
Most 3-stage o 3-stage plus like my progressive dynamics wizard controlled NO
In fact I do that.
^ Why do you say that?
I recently got a charge wiz for my PD converter and the specs look like it floats at the right voltage and maintains properly.
FWIW, PD claims it's safe and the specs don't say otherwise.
Lynnmor
I disconnect and charge the batteries about 3 days per month. Keeping the cord connected exposes the RV to lightening and any power line issues.
dryfly
Is it not easier to just disconnect the battery when connected to shore power for an extended time? Ever 2-3 reconnect for a couple of days for a charge. Less trouble than having to check for water in my case.
Lwiddis
Solar charging eliminates need to plug in while in storage
wa8yxm
Magnetek 6300 or other ferroresonate converter YES
parallex 7300 (parallex bought out Magnetek and did an upgrade) possible but not likely
In fact I do that.
garyemunson
Always check battery water. I've found in my case monthly is sufficient. Depends on how strong your charger maintains your batteries. Keep an eye on the water for 6 months or so and you will learn how often you need to check on them.
bikendan
my TT is always plugged into shore power, when parked at home.
just check battery water level once a month.
tropical36
I do and a good charger will go down to a trickle and not boil the water out.
Even so, I have AGM's and maintenance free for the chassis, so pretty good, either way...
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
rk911
nope, other than possibly boiling your batteries. if you have a standard battery charger with no float or maintenance stage you could damage your batteries. if you have a 'smart' or 3-stage charger you should be ok. google the make and model of your charger.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
mikim
Check the water level in the battery frequently. Some say monthly, I usually did it every two weeks.
